Math help - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: Math help
    bmw m3
    Default Math help
    I have a math upgrade test at sait on thrusday n i need help on these question havent taken math since last semester so i forgot some of this shit. Hope u can help me out its number 40 n 41 thanx lots
    18 GTI, 07 MX-5, 92 400E, 09 Cayenne
    Default Re: Math help
    bmw m3
    yea its beging gay
    bmw m3
    yo
    335i
    D & B
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Jul 2002
    06 RX8 SE
    whats so hard about it.. you just multiply it out ( the answers) and see if it make sense
    like m^2 X 144m^7 doesnt take alot of math skill to do
    Apr 2003
    Originally posted by Weapon_R
    D & B
    , comon justin; its only math applied
    Professional DJ equipment for sale: Click Here
    Oct 2002
    04 maxima, 03 ML320
    man i dont miss high school......iam sure i did that back in the day, looks confusing.
    bmw m3
    41 seems like u dont do anything just put the number together
    bmw m3
    Someone tell me how to do 40
    Jul 2002
    06 RX8 SE
    the answer just happens to be like that..
    best way to learn through that 2 questions is to work out each answer and see which one matches the question.
    if you do that to Q41 you will find out a, c and d doesnt equal to the given equation
    Jul 2002
    06 RX8 SE
    if you are multiplying the power together ( ie X ^ 4, 4 is the power.) then you jsut add the 2 powers together.
    so for example
    16m X 2m^2
    16 X 2 is 21
    m X m^2 = m^3 cuz you are adding the power together..
    or if your question is how would you get the answer if its not m-choice..
    then all you do is look and see if anything is in common w/ each set of numbers.
    ie .. they all have [m] to the power of something..
    so you take out the lowest power.. m^2.. bring it to the front and subtract m^2 to all the numbers.. same w/ the integers
    bmw m3
    still dont c how it relates to the top 144m9-160m7-96m2
    Jul 2002
    06 RX8 SE
    16m^2(9m^7 - 10m^5 - 6)
    you just multiply each one out. .this is Jr high concept
    16m^2 X 9m^7 = (16X9) ( m^2 X m^7)
    16X10.. simple enuf
    ( m^2 X m^7).. since its multiply.. you ADD the power together..
    7+2 = 9..
    you do that to 16m^2 X 10 M^5 and 16m^2 X 6
    etc..
    and since it is minus.. you keep the minus.. and voila.
    2008 Honda Civic
    the common factor is the one number that can be applied to all the other numbers in the equation, theres only one answer being d because you can take 16m^2 out of each number, the other two (b and c) do share a common factor but your missing the other common factors aswell (your trying to break down an equation as much as possible)...hope i made some sense blah haaha
    if u chose 16 as a common factor your missing that you can also take out m^2
    and vice versa
    so it only makes sense to pick the answer with a common factor of both 16 and m^2, therefore 16m^2 DUH!
    bmw m3
    so is that list of numbers like 144 so on just a example?
    2008 Honda Civic
    144, 160, and 96 as you can see can be broken down by 16 as an example...it could be 8, 6, and 4 for all it matters, the common factor being 2...no diff
    Apr 2003
    u factor out the most common pairing, ok the answer is D: 16m2 (9m7 -10m5 -6)
    16m2 is being factored out from the original numbers (144m9-160m7-96m2)
    16m2 goes into 144m9; 9m7 times
    16m2 goes into 160m7; 10m5 times
    16m2 goes into 96m2; 6 times
    so u put the largest factored number outside the brackets (16m2) and the new multiples i just showed u on the inside (9m7 -10m5 -6)
    bmw m3
    So ur lookin for a common factor so that leaves c , d , but d has the common factor of 2 also thank alot dude u helped me tons.
    bmw m3
    booooyaaaaa ic it
  1. Rice Math?
    By atomic in forum Campus Chat
    Latest Threads: 06-10-2003, 04:08 PM
  2. Help edmonton guys...help asap please
    By TomTom in forum General Car/Bike Talk
    Latest Threads: 07-20-2002, 11:31 PM
