1993 Camaro Z28
383 LT1 V8
Callaway Honker
52mm TB
Ported heads
XE 230/236 .544/.555 cam
R-lifters by Comp
Comp Cam Pro Magnum 1.6 rockers
Comp 987 valve springs
SRP forged pistons
Eagle H-rods
Scat Crank
King Bearings
Fluidamper balancer
30# SVO Injectors
ACCEL adjustable fuel regulator
Walbro fuel pump
Hooker 1 3/4" Long Tubes
Custom 2.5" True Duals
Dynomax Super Turbo Mufflers
700R4 Tranny
TCS 3200 Converter
Tranny cooler
Trans Go shift kit
Fluidyne Radiator
10" pusher fans + stock fans
Fastchip Programming
Dual Prom PCM
Sybersport Double Diamond Subframe Connectors
Spohn Lower Control Arms
Spohn Relocation brackets
Firestone Airbag in passenger rear coil
Polyurethane Energy Suspension bushings
Hal 12 way adjustable shocks
LS1 twin piston front calipers and rotors.
Billet Specialties rims
Nitto Drag Radials
Assembled by Brian Wheatley.
Interior: Too much too list. Lots of fibreglassing.
