Integra radio antenna questions! - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: Integra radio antenna questions!
    Dec 2005
    12 TL
    Default Integra radio antenna questions!
    Okay, so my car's audio is bone stock and I was just wondering if my stock antenna's suppose to go up whenever the radio is on?
    Reason why I ask is because it never goes up, I can't seem to find a button to make it go up and seems like my car has terrible reception for the radio, it gets really fuzzy from time to time whenever I'm driving normally, HELP!!
    Any way to fix it?
    Feb 2005
    Ive only seen a handful of them actually work. You can either pull it up manually and it will stay there, you can buy a new OEM antenna or you can retrofit a S2000 one in it's place.
    I got pretty decent reception with mine stuck all the way down.
    Dec 2005
    12 TL
    ^ thanks for the quick replies, do you guys know the prices to get an oem reinstalled?
    I think the OEM mast is around $90.
    http://www.g2ic.com/tegtips/exterior/11.html
    Have fun!
    Oct 2004
    The antenna is suppose to go up unless there is a break in the circuit. Maybe the former owner of the car did it on purpose. Integras are notorious for having noisy antennas. When the thing starts rusting you'll hear the motoring grinding to get the antenna down.
    You can try looking behind your audio deck and see if one of the wires have been cut. Another place could be at the antenna motor, but it's a bit harder to get to.
    Either that or the motor is just shot, you can always pull the antenna up manually...
    Oct 2004
    DIY
    http://www.team-integra.net/sections...?ArticleID=859
    Dec 2005
    12 TL
    Thanks !! ^
    This could be a fun weekend project lol..
    Sep 2003
    99 1.8t
    dang hate to say it but that looks weak. i would never put something like that on my car
    Dec 2005
    12 TL
    ^ lol, yeah. I'm just going to try to fix the current antenna or buy a replacement.
    Apr 2004
    Honda Civic 1995, 1996 Acura Integra
    haha check to see if the connector to the motor is disconnected first. haha my antenna blows ass.. i fixed it twice.. and after a while it does the samething.. that stupid grinding noise when it goes up and down.. can you hear the motor turn when you turn the radio on?
    Oct 2004
    I have the same problem with mine, but when the radio comes on the antenna comes up about 6 inches. Which is cool I guess, I wouldn't want it to go the whole way up. It just sucks when you get crappy reception (especially on 92.9 wtf)
    The SHBARUS
    I had the same problem on my old car. The reason is that dirt tends to stick on the antenna. When it retracts, some dirt will be brought down into the bottom of the antenna. Dirt builds up and eventually it either doesn't work as good or it will stop working all together.
    If you want to use similar type of antenna, you should keep it clean as much as you can. It's a bit annoying to get out of the car, wipe the antenna before you shut the car and the stereo off.
    Dec 2005
    12 TL
    Lol, there's no sound at all, it's like the things not even connected to the car itself.
    Jun 2004
    Calgar3h
    S14|TB1
    ^ like said above, the dirt gets stuck in the telescopic antenna and usually it goes up halfway and makes the noise of the stuck motor, get an aftermarket rubber one, like the ones on Vdubs.
    try squirting some silicone lube or what not and retracting it up and down.
    07 F-150
    Default Signal??
    check to make sure your head unit is sending a signal to the motor the wire your looking for is yellow with green stripe, motor located at i believe drivers rear behind pannel, hope this helps a little
    Dec 2003
    2011 Audi TTs
    antenna motors are notorious for failing after a couple years, my year of camry has one, and so does the respective lexus model, and i havent seen a single one that works 100% (the antenna is effing long if it actually gets to its proper extended height), its probably 100% a dead motor, or just a dirty antenna that has too much friction to get up. anyone know where to get replacement camry antenna's? haha
  1. Swapping the stock radio for a Bluetooth Compatible radio
    By 85Supra in forum In Car Entertainment / Electronics
    Latest Threads: 04-04-2007, 10:21 AM
  2. FS: XM radio car antenna
    By Sk8erlude in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-24-2007, 08:33 AM
  3. Satalite Radio Questions
    By EnRich in forum In Car Entertainment / Electronics
    Latest Threads: 01-09-2006, 11:30 AM
  4. US Sirius Radio vs Canadian Sirius Radio
    By likwid in forum In Car Entertainment / Electronics
    Latest Threads: 12-11-2005, 01:58 AM
  5. FS: Alpine XM radio box + Antenna (brand new)
    By Hash_man in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 04-06-2005, 11:01 PM
