Here are some pics finally of the car.
It is a 2005 Cadillac CTS-V
400hp/395ft-lbs from a 5.7L LS6 V8, 6spd Tremec Manual Trans, Independant rear with 3.73's.
14" Brembo rotors mated with 4-piston Brembo calipers on all four corners to dust up the wheels almost as quickly as they stop the car!
Heated Leather seats with Suede inserts. Sunroof, Navigation, XM Radio, etc etc...
The Controls on the steering wheel change the Display from a G-Force Gauge(very cool!), Tire Pressure for each tire, Transmission temp, oil temp, oil pressure and coolant temp. even though there is a coolant temp gauge. Also displays digital speedo and odometer in any combonation of the 2 or none at all on the other display. Also Traction Control on or off. and the other side controls cruise.
Don't ask me where I took the pics because now you know. ;D
The 400hp LS6 Powerplant is somewhere under that plastic.
I hate that damn front license plate bracket. Unfortunatly it is riveted on with 4 rivets. I am thinking of just getting a license plate like this fro the front.
