2008 LS3 Corvette sneak peak - Beyond.ca - Car Forums
Results 1 to 20 of 37
Thread: 2008 LS3 Corvette sneak peak
    Feb 2003
    Winnipeg, Manitoba
    383 Camaro LT1
    Default 2008 LS3 Corvette sneak peak
    This is a 2008 3LT Z51 A6.
    GU2 performance axle is 2.73 gearing.
    93 Camaro Z28 (The fast one)
    01 Trans Am WS6 (The cute one)
    Esla T6 Dog Sled (Not cute, not fast, scary as hell)
    Feb 2003
    Winnipeg, Manitoba
    383 Camaro LT1
    6.2 litres
    Displacement on Demand
    430hp (although some say anywhere between 425 and 450)
    well over 30mpg on the highway
    overall reduction of 18lbs compared to the LS2
    higher compression
    variable valve timing (VTEC just kicked in YO!)
    Feb 2003
    Winnipeg, Manitoba
    383 Camaro LT1
    T2S
    pedals
    30 hiway mpg is rad
    Oct 2004
    wow, that is a hot car.
    Carolina
    GMC Acadia
    Can't wait to pick up an LS2 C6 for (relatively) cheap some time soon
    Originally posted by VIZSLA
    Seems that running qualifying in three heats worked so well we're now running the race in three parts too.
    1, On the track
    2, In the steward's box
    3, In Paris
    May 2005
    Mountains/Calgary
    Das Fahrenheit
    Originally posted by 89coupe
    I do get great service there, especially when I mention my name, haha.
    Toronto, ON
    S54 M Coupe
    I understand it's just a mule, but they really need to work on that interior.
    Jan 2006
    Too much red in the interior (I hate red in interiors) but looks great.
    May 2003
    Lethbridge
    07 Speed3
    So I take it since the camshaft is in the block and actuates on all the valves, that the intake and exhaust is variable only in the same ratio? Meaning they cannot be varied independently of each other? My brain hurts
    Gotta love boost
    05 GSXR600
    corvette schmorvette
    Feb 2003
    Winnipeg, Manitoba
    383 Camaro LT1
    Feb 2003
    Winnipeg, Manitoba
    383 Camaro LT1
    Engines
    6.2L V-8 LS3
    7.0L V-8 LS7 (Z06)
    Displacement (cu in / cc):
    376 / 6162
    427.6 / 7008
    Bore & stroke (in / mm):
    4.06 x 3.62 / 103.25 x 92
    4.125 x 4 / 104.8 x 101.6
    Block material:
    cast aluminum
    cast aluminum
    Cylinder head material:
    cast aluminum
    cast aluminum
    Valvetrain:
    overhead valve, 2 valves per cylinder
    Fuel delivery:
    SFI (sequential fuel injection)
    Compression ratio:
    10.7:1
    11:1
    Horsepower
    (hp / kW @ rpm):
    430 / 321 @ 5900* w/ std. exhaust
    436 / 325 @ 5900* w/ opt. exhaust
    505 / 377 @ 6300*
    Torque (lb-ft / Nm @ rpm):
    424 / 575 @ 4600* w/ std. exhaust
    428 / 580 @ 4600* w/ opt. exhaust
    470 / 637 @ 4800*
    Recommended fuel:
    premium recommended but not required
    premium required
    Estimated fuel economy :
    TBD
    TBD
    Transmissions
    6-speed manual
    Base and Z06
    6-speed manual, w/optional Z51 Performance Package
    6-speed paddle-shift automatic
    Application:
    std
    opt
    opt
    Gear ratios (:1):
    First:
    2.66
    2.97
    4.03
    Second:
    1.78
    2.07
    2.36
    Third:
    1.30
    1.43
    1.53
    Fourth:
    1.00
    1.00
    1.15
    Fifth:
    0.74
    0.71
    0.85
    Sixth:
    0.50
    0.57
    0.67
    Reverse:
    2.90
    3.28
    3.06
    Final drive ratio:
    3.42
    3.42
    2.56
    Chassis / Suspension Coupe and Convertible
    Z06
    Front:
    short/long arm ( SLA ) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
    Rear:
    Traction control:
    electronic traction control; Active Handling
    Brakes
    Z06
    Type:
    front and rear power-assisted disc with ABS; cross-drilled rotors with Z51 package and Magnetic Ride Control
    front and rear power-assisted disc with ABS with 6-piston front and 4-piston rear calipers, cross-drilled rotors
    Rotor diameter x thickness (in / mm): front: 12.8 x 1.26 / 325 x 32
    rear: 12 x 1 / 305 x 26;
    Z51 Performance Package:
    front: 13.4 x 1.26 / 340 x 32
    rear: 13 x 1 / 330 x 26
    front: 14 x 1.3 / 355 x 32
    rear: 13.4 x 1 / 340 x 26
    Wheels & Tires
    Wheel size:
    front: 18 inch x 8.5 inch
    rear: 19 inch x 10 inch
    front: 18 inch x 9.5 inch
    rear: 19 inch x 12 inch
    Tires:
    Goodyear Eagle F1 Supercar (w/Z51)
    Extended Mobility
    front: P245/40ZR18
    rear: P285/35ZR19
    Goodyear Eagle F1 Supercar Extended Mobility
    front: P275/35ZR18
    rear: P325/30ZR19
    Dimensions
    Z06
    Wheelbase (in / mm):
    105.7 / 2685
    105.7 / 2685
    Overall length (in / mm):
    174.6 / 4435
    175.6 / 4460
    Overall width (in / mm): 72.6 / 1844
    75.9 / 1928
    Overall height (in / mm):
    49 / 1244
    49 / 1244
    Curb weight (lb / kg):
    Coupe: 3217 / 1459
    Conv.: 3246 / 1473
    3162 / 1434
    Interior
    Seating capacity
    2
    Interior volume (cu ft / L):
    52 / 1475 (all models)
    Headr oom (in / mm): 38 / 962 (all models)
    Legroom (in / mm): 43 / 1092 (all models)
    Shoulder room (in / mm):
    55 / 1397 (all models)
    Hip room (in / mm):
    54 / 1371 (all models)
    Capacities
    Cargo volume
    (cu ft / L):
    Coupe and Z06: 22 / 634
    Convertible: 11 / 295 (top up); 7.5 / 212 (top down)
    Fuel tank (gal / L):
    18 / 68.1
    Engine oil (qt / L):
    Coupe and Convertible: 5.5 / 5.2
    Z06: 8 / 7.5
    * Horsepower and torque are SAE certified. A new voluntary power and torque certification procedure developed by the SAE Engine Test Code committee was approved March 31, 2005 . This procedure (J2723) ensures fair, accurate ratings for horsepower and torque by allowing manufacturers to certify their engines through third-party witness testing. GM was the first auto manufacturer to begin using the procedure and expects to use it for all newly rated engines in the future.
    Note: Information shown is current at time of publication.
    Jun 2005
    2016 Golf
    Feb 2004
    2015 honda crv 2015 subaru sti sport
    Nov 2005
    A Slow Car
    How much will it go for?
    2007 Lexus RX 350
    2004 BMW X5 SOLD
    2003 G35 Coupe For Sale
    1998 Camry CE V6 SOLD
    1995 Z28 LT1 M6 Modded (Torque Monster) SOLD
    1994 Camry LE 2.2L (Written Off)
    1991 Nissan Maxima SOLD
    1990 Honda Civic DX HB SOLD
    1982 Datsun 280ZX SOLD
    14 ZL1
    Not necessarily, the camshaft can be two in one. The outer cam could control the intake valves and be hollow, while a cam running inside the intake cam can run the exhaust valves. This way they can be independently adjusted.
    The new Viper is running this system, and I don't see why GM couldn't either. However, GM has not announced how it is doing this.
    Mike
    14 ZL1
    07 Mazdaspeed3
    Feb 2004
    i actually really like the interior!
    red interior is hot
    Mar 2007
    550i, X5
    red interior is hot
    I seriously thought I was the only one. I think red is the nicest interior out there....except for maybe the rust looking orange u can get in the e46 M3
    Originally posted by rage2
    Of course, a perfectly good explanation is boring, so the answer is, it's fucking voodoo.
    I hope they upped the interior quality/fit & finish a whole ton, I will have to go look at one for myself when they come out. The C6's are fun to drive but I look around me and feel like I'm in a $20,000 car. The new one looks better but we'll see.
  1. Detroit Sneak Peak: Lexus IS-F
    By benyl in forum Automotive News
    Latest Threads: 12-29-2006, 04:48 PM
  2. Replies: 53
    Latest Threads: 03-12-2006, 04:32 AM
  3. Corvette "SS" with LS9 for 2008
    By Gripenfelter in forum Automotive News
    Latest Threads: 11-21-2005, 06:31 PM
  4. SNEAK PEAK! Corvette launch commercial!
    By im_barky_elks in forum General Car/Bike Talk
    Latest Threads: 08-13-2004, 11:58 PM
  5. BMW M5 Sneak Peak
    By Gripenfelter in forum Cars, Bikes, Machines
    Latest Threads: 07-23-2003, 05:40 PM
