I have a rear wheel drive car and want to bust some sick brakestand burnouts but do'nt know how to could some one help me?
put the car in neutral, stand on the brake... rev it a few times, put it back into drive, floor it and let off the brake.
ohhh shit the 14 year old ladies are gonna be over you man, iam jealous!!
hook up a handbrake and have at it
HAHAHA this is the funniest thread I've ever seen.
Seriously though this is how you do it:
1) Get in car
2) Stand on brake
Viola! Brakestand.
You can also be in neutral, forward, reverse (if you car is so equipped) or any combination of the two (or three if your car is so equipped). You can have the e-brake on, or off, windows up or down, doors opened or closed. But do make sure that your car has tilt steering, otherwise it won't work.
good shitOriginally posted by 5.9 R/T
1) Get in car
2) Stand on brake
Viola! Brakestand.
ok seriously.... how difficult is this
you get in your car turn the key until the car starts, then you put your foot on the brake put the little stick that tells you which gear your in, in drive put your put on the gas slowly as you do this your car should slowly have the feeling of liftin up and finally the tires will start spinning you can do this until which ever time you would like(burn your tires off if you want) but then let off the bale and your tires will grip the pavement and your off
this applies to rear wheel drive vehicles...
and if you have standard its more fun
i hate it wen ppl brag up thier cars,and tell me shit that i can plainly see that they haven't done. and expect me to believe it, hopeing that i am as ignorant and full of bs as them, well I'M NOT
