Problem with Ford wiring. - Beyond.ca - Car Forums
Results 1 to 3 of 3
Thread: Problem with Ford wiring.
    Sep 2006
    2005 Honda Civic
    Default Problem with Ford wiring.
    My dad has a 1998 Ford Explorer fully loaded and the power lock function on the driver side door doesn't work anymore. I wanted to know if it was the button so I removed the button by taking the door apart and plugged the button in upside down on the passenger side. It worked perfect. So then I tested the power connections in the door with a voltmeter and the pink/yellow wire on the driver side is not getting power while the same wire on the passenger side is. There's 2 black wires, a red/black wire, a pink/green wire and a pink/yellow wire. The 2 pink wires are supposed to be hot and the blacks are grounds. The wires look perfect, I even sliced it up higher and tested it there but there's still no power in it anywhere. How far back do you think the problem is and what could it be? Any suggestions?
    Originally posted by adamc
    you can pretty much skip over any posts that have no punctuation, as a general rule of thumb.
    Sep 2005
    calgary, ab
    There's a good chance the fault will be at the door hing or nearby there.
    Sep 2006
    2005 Honda Civic
    Ya, pinched hey? But the wiring as far as I can see runs from the buttons in the door to the selenoid which controls the locks. But I guess it must run through the hinge, I'll take a look and see if anything rubbed.
  1. 98 Chevy Malibu wiring problem
    By D911 in forum In Car Entertainment / Electronics
    Latest Threads: 04-19-2006, 06:23 PM
  2. NEED HELP!! sub wiring problem
    By _integra_typeR_ in forum In Car Entertainment / Electronics
    Latest Threads: 07-24-2005, 01:40 AM
  3. Need Some Wiring Help Please....*Wiring GURUs Enter Here!*
    By Weapon_R in forum In Car Entertainment / Electronics
    Latest Threads: 04-21-2005, 06:38 PM
  4. Door Speaker wiring problem
    By [CyRus] in forum In Car Entertainment / Electronics
    Latest Threads: 02-16-2005, 11:50 PM
  5. New Deck - Wiring problem, need help...
    By Speed_RaSiR in forum In Car Entertainment / Electronics
    Latest Threads: 06-02-2004, 10:45 AM
