A/C recharge - Page 2 - Beyond.ca - Car Forums
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 42
Thread: A/C recharge
  1. #21
    Jul 2007
    Blue boy
    A&M mobile mechanic
  2. #22
    I've used Jonathan Sniezek ....Cell - (403) 921-8529.... good mobile mechanic who operates out of his van.
    Young guy but very good at what he does. In addition to other work, he recharged my Civic's AC last fall at my request. Turns out there is a failed part (evaporator I think) so I will be calling him again for a charge once the part is replaced.
  3. #23
    Oct 2006
    Z
    The fittings in those kits do not thread onto mine so I wanted to let a shop deal with it. I have no idea why not but every R12 adaptor I've used does not work
    No shop suggestions?
    Edit will call Jonathan
    Z32 TT
    2002 WRX - to be sold
    2010 sti - winter
  4. #24
    6.7 CUMMINS, E50 AMG
    you can buy the quick connect adapters at refrigeration supply but i think they are around $100
  5. #25
    Old thread bump. Savage Honda fit isn't blowing cold like it used to. Compressor is definetly cycling, and air is cool-ish, but not cold enough. Being the cheapskate I am, should I just get the recharge kit and go to town or pay someone to inspect?
  6. #26
    I got an AC recharge done for 80$ at - Calgary Auto Repair Services. Very prompt and very kind. Added leak test to check for future issues if need be.
    https://goo.gl/maps/BT5w4pWKN6u
  7. #27
    Aug 2005
    2007 4Runner
    I just had the wife's VW Golf tested for leaks and recharged at Budget Auto Repairs over in the NE. Place was a what you think for the area it is in (just off of 52nd and 17th ave) but no appointment needed, guys were great and $100 cash.
  8. #28
    Dec 2008
    Those kits are the worst. They often contain stopleak which is just a horrible idea for anything (coolant system, tires, oil, A/C). The “gauge” they have is equivalent to a narrowband O2 when you really need a wideband. They also don’t give you any way of testing if the compressor is functioning properly which a shop will no doubt do (meausuring high and low side).
    I vote no on the Canuck tire DIY kits
  9. #29
    Aug 2011
    Strathmore
    2005 Dirtymax
    Inspect. You have a leak which will mean repairs. If you don't care about your car or the AC then use a recharge system.
  10. #30
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    I just recharged my Zonda last week. After four years I finally have AC again!!!
    I bought one of those DIY kits from Auto Value ($57). It was not working at first, then after youtubing I got someone to hold the throttle at 2500 rpm while I recharged.
    I have cold air!!! No more sweaty balls..
  11. #31
    Jul 2006
    Victoria Park
    You have a Zonda?
  12. #32
    Sep 2016
    Calgary, Ab
    2021 Zonda CRV
    You have a Zonda?
    Hell yeah. Zonda CRV...baby.
    2002, 346,00km,.. 2.4 Litres of Samurai Engineering, fully manual, cruise control, Sheek 90's style plastic interior and it even comes with a picnic table...I shit you not.
    If your even in the SE, I'l take you for a spin.
  13. #33
    Aug 2011
    Strathmore
    2005 Dirtymax
    The picnic table is the best part!
  14. #34
    Oct 2008
    South of Calgary
    is broken
    BUMP. Its getting hot and my X5 is even hotter. Need a recharge from someone that knows BMW. Recommendations?
  15. #35
    In researching repairing my R12 AC in the Miata, I've come to realize that pretty much every shop does R134 pressure test, seal replacements, vacuum and recharges. Integra Tire was going to do mine until I got my R12 system fixed.
  16. #36
    Jun 2003
    Found a 2003 LS 430 that needs the AC repaired, does not blow cold air at all. I’m assuming AC compressor is shot or maybe it’s an easier fix? Any recommendations for a shop?
  17. #37
    Sep 2008
    Turbo stuff
    Usually a leak, and the leak is usually just o rings on the connections. Less common is a leak from a hose or the condenser took a rock. Even less common than that would be a bad compressor. Wiring problems can also pop up in older cars AC systems.
  18. #38
    Jun 2003
    I spoke to the sellers and Lexus diagnosed it as a failed compressor. So I think I’m going to have to pass on this car.
  19. #39
    Quote Originally Posted by jacky4566 View Post
    Did my X and it's relatively straight forward with diy kit.
    Mine has a slow leak and I'm too lazy to replace seals, I just recharge it every spring. Works for summer and all good.
  20. #40
    Mar 2010
    Ioniq 5
    Quote Originally Posted by Clever View Post
    Can you just get a replacement from rock auto for cheap, swap it and get it recharged? Depends on the car I guess but some it's just pop the belt of, 2 bolts, 1 electrical connection, and the 2 hoses. Not the worst, though the Lexus may be a cluster fuck of stuff in the way i guess
  1. Air Conditioning recharge kits
    By Forkster in forum General Car/Bike Talk
    Latest Threads: 06-17-2005, 03:29 PM
  2. Can I recharge the A/C on a '94 Civic myself?
    By Super_Geo in forum General Car/Bike Talk
    Latest Threads: 05-24-2005, 08:00 PM
  3. Air Conditioning Recharge
    By oneshot in forum General Car/Bike Talk
    Latest Threads: 05-18-2005, 11:32 AM
  4. who does A/C recharge cheep
    By TomTom in forum General Car/Bike Talk
    Latest Threads: 07-29-2004, 02:36 AM
  5. wtb: foam type air filter recharge kit
    By mtakako in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 07-15-2004, 03:26 PM
