FS: Cisco CCNA/CCNP Equipment - Routers and Switch - Complete Lab - Beyond.ca - Car Forums
Results 1 to 3 of 3
Thread: FS: Cisco CCNA/CCNP Equipment - Routers and Switch - Complete Lab
    Subaru Outback
    Default FS: Cisco CCNA/CCNP Equipment - Routers and Switch - Complete Lab
    I am posting this For Sale ad on behalf of a friend. Please contact him at [email protected] if you have any questions about the equipment.
    The following Cisco routers and switch are no longer required for CCNA/CCNP study and are up for sale. I'd like to pass along a good deal to someone in need of hands on practice. I have a pile of console, serial, and ethernet AUI's as well - enough to get a nice home lab up and running. Of note is the Cisco 2511 Access Router which will allow you to connect up to 16 console connections at a time via reverse telnet. I'm not looking to part this package out at this time. For all equipment I'm looking to get only $575.00
    The following devices are included. Six are fully operational and two non functional which I suspect require new RAM. If you want the non functioning devices great, if not the price is the same. I giving them away as part of the package, someone may have the time to fiddle with them, I don't. Again, the price is $575.00
    Please email [email protected] for pictures if required. I want this equipment gone by the weekend.
    Cisco 1605R
    cisco 1605 (68360) processor (revision C) with 23733K/843K bytes of memory.
    Processor board ID 08435419, with hardware revision 00000000
    Bridging software.
    X.25 software, Version 3.0.0.
    2 Ethernet/IEEE 802.3 interface(s)
    System/IO memory with paAM onboard 16384K bytes of DRAM on SIMM
    System running from RAM
    7K bytes of non-volatile configuration memory.
    16384K bytes of processor board PCMCIA flash (Read/Write)
    Cisco 2611
    cisco 2611 (MPC860) processor (revision 0x202) with 49152K/16384K bytes of memory.
    Processor board ID JAD04010J22 (1827728703)
    M860 processor: part number 0, mask 49
    Bridging software.
    Basic Rate ISDN software, Version 1.1.
    1 Serial network interface(s)
    1 ISDN Basic Rate interface(s)
    32K bytes of non-volatile configuration memory.
    8192K bytes of processor board System flash (Read/Write)
    Cisco 2611
    Bridging software.
    2 Serial network interface(s)
    Main memory size: 64 MB.
    Available main memory starts at 0x10000, size 65472KB
    IO (packet) memory size: 20 percent of main memory.
    NVRAM size: 32KB
    Cisco 2511
    cisco 2511 (68030) processor (revision C) with 16384K/2048K bytes of memory.
    Processor board ID 01455401, with hardware revision 00000000
    Bridging software.
    SuperLAT software copyright 1990 by Meridian Technology Corp).
    TN3270 Emulation software.
    , BFE and GOSIP compliant.
    1 Ethernet/IEEE 802.3 interface(s)
    16 terminal line(s)
    16384K bytes of processor board System flash (Read ONLY)
    Cisco 2514
    cisco 2500 (68034336K/2048K bytes of memory.
    Processor board ID 01502972, with hardware revision 00000000
    Bridging software.
    SuperLAT software (copyright 1990 by Meridian Technology Corp).
    2 Ethernet/IEEE work interface(s)
    Cisco 2522
    NOT FUCTIONING Prob. requires new RAM
    Cisco 2501
    Cisco 2514
    cisco 2500 (68030) processor (revision L) with 2048K/2048K bytes of memory.
    Processor board serial number 01904066
    Bridging software.
    X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
    Primary Rate ISDN software, Version 1.0.
    2 Ethernet/ network interfaces.
    4096K bytes of processor board System flash (Read ONLY)
    Cisco Catalyst 2912
    Cisco Internetwork Operating System Software
    IOS (tm) C2900XL Software (C2900XL-H2S-M), Verson 11.2(8.2)SA6, MAINTENANCE INTERIM SOFTWARE
    Copyright (c) 1986-1999 by cisco Systems, Inc.
    Compiled Wed 23-Jun-99 17:48 by boba
    Image text-base: 0x00003000, data-base: 0x002432D0
    Initializing C2900XL flash...
    flashfs[5]: 171 files, 4 directories
    flashfs[5]: 0 orphaned files, 0 orphaned directories
    flashfs[5]: Total bytes: 3612672
    flashfs[5]: Bytes used: 1828864
    flashfs[5]: Bytes available: 178808
    flashfs[5]: flashfs fsck took 6 seconds.
    flashfs[5]: Initialization complete.
    ...done Initializing C2900XL flash.
    C2900XL POST: System Board Test: Passed
    C2900XL POST: CPU Buffer Test: Passed
    C2900XL POST: CPU Notify RAM Test: Passed
    C2900XL POST: CPU Interface Test: Passed
    C2900XL POST: Testing Switch Core: Passed
    C2900XL POST: Testing Buffer Table: Passed
    C2900XL POST: Data Buffer Test: Passed
    C2900XL POST: Configuring Switch Parameters: Passed
    C2900XL POST: Ethernet Controller Test: Passed
    C2900XL POST: MII Test: Passed
    cisco WS-C2912-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory.
    Processor board ID 0x0D, with hardware revision 0x01
    Last reset from power-on
    Processor is runnig Enterprise Edition Software
    Cluster member switch capable
    12 Ethernet/IEEE 802.3 interface(s)
    32K bytes of flash-simulated non-volatile configuration memory.
    Base ethernet MAC Adress: 00:30:19:33:17:40
    Motherboard assembly number: 73-3397-07
    Power supply part number: 34-0834-01
    Motherboard serial number: FAA03399PEP
    Power supply serial number: NONE
    Model reision number: A0
    Model number: WS-C2912-XL-EN
    System serial number: FAA0340G0NS
    Aug 2004
    09 wrx265
    ygpm
    Aug 2004
    09 wrx265
    one of the Cisco 2611 flash didnt have any IOS in it, but got everything to run.
    thanks pacman and kelly, this will help me with my studies and certificate exams
  1. FS:Herman Miller Medical Lab Equipment
    By 4wslude in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-27-2007, 03:50 PM
  2. WTB: Cisco Networking Hardware
    By Velox in forum Computer Hardware & Peripherals
    Latest Threads: 07-05-2005, 04:16 PM
  3. WTB: Cheap P1/P2's, KVM switch or Monitor only switch, Small HDD's
    By AllGoNoShow in forum Computer Hardware & Peripherals
    Latest Threads: 05-07-2005, 10:40 PM
  4. Thinking about doing my CCNP
    By Hollywood in forum Campus Chat
    Latest Threads: 10-06-2003, 01:25 AM
  5. CCNA/CCNP Courses at SAIT
    By SI-vic in forum Campus Chat
    Latest Threads: 05-02-2003, 04:20 PM
