LED Light bulbs? - Page 24 - Beyond.ca - Car Forums
Page 24 of 38 FirstFirst ... 14 23 24 25 34 ... LastLast
Results 461 to 480 of 744
Thread: LED Light bulbs?
  1. #461
    Feb 2008
    AMGGGGGGsixtythree
    Originally posted by Kjonus
    Looking for painted cap led light bulbs anyone seem them around
    as in silver-ish ? You can lightly spray it with a spray paint.
  2. #462
    Are you talking about something like this?
    https://www.homedepot.ca/en/home/p.l...001010089.html
    They had 6 or 7 different colors at Home Depot when I was there.
  3. #463
    Grimace
    Saw these bulbs at home depot
    https://www.homedepot.ca/en/home/p.l...001015361.html
    Not dimable but have three different colors, 5000k, 2700k and 2200k. You just flip it off and on to switch modes and it stays on the last mode when turned on. $13 and 9.5 w.
  4. #464
    Aug 2005
    2007 4Runner
    Nope something like this but in an LED
    Link
  5. #465
    Feb 2003
    I switched my kitchen fixtures to MR20 narrow floods, 3 in each fixture. Gives off the same amount of light as a single fixture with a high wattage bulb, and I have the ability to aim each bulb for the desired lighting effect. Not cheap going this route but it looks way better being able to control direction of the lights without blinding anyone in the kitchen. I have most of them pointed at my white cabinets with diffuses the light nicely.
    I did the same thing in the garage, but pointed at the cars for a showroom look. As for the opener, people say not to use LEDs due to vibration, but I've had no problems with them. If anything, the vibrations killed incandescent bulbs much quicker. Try a couple of different bulbs to figure out what works in the garage opener enclosure, as they all have bulb placement and the plastic light diffusing cover slightly different depending on model.
    Which brand of LED did you use? I'm curious to switch my kitchen and main floor pot lights over. I was going to go to Costco today to pick up 30 par 20 led floods, but do appreciate your suggestion if you think there are better options.
    2016 Tesla Model X
    2018 Lincoln Navigator
    2016 Porsche GT3 RS
  6. #466
    Dec 2008
    Funny, I switched to a LED in the opener because vibration problems kept killing the incandescent light bulbs really fast on my opener. LED has already paid for itself by outlasting the incandescent ones by more than 3x.
  7. #467
    BoostLand
    something green
    Every time I've gone to the wholesalers to buy Led bulbs, they've given me free sample bulbs. My whole house is now LED, I think I've spent 25 buck total on conversion.
    Makes up for the exterior LED fixture I picked up and later got billed $300 for.
    Our upstairs bathroom had a fixture that took 8 25 watt bulbs, after swapping to LED, its brighter, but also a lot colder in the winter months.
    Too loud for Aspen
  8. #468
    I started the conversion pretty early on, so I've tried all the brands. Pretty much all of them had a small # of failures, Feit had the worst track record at around 40% failures since the start of the thread, and Philips with 0. Well 1 failed when it was dropped from the roof during renovations but that doesn't really count. Philips bulbs are by far the most reliable LED bulbs out there where I'd say have an actual chance of lasting the 20 year life that they promise.
    When Philips started offering more and more of their bright white color temps, that was close enough to my ideal color temp in my more active rooms, plus the light distribution is the closest to typical incandescent bulbs, and as such I've switched almost every bulb in the house to Philips. There are 2 rooms that still warrant a slightly cooler color than the bright whites, where I'm using the remaining of my Feits.
    So for reliability sake, Philips is the clear winner, but I would really experiment with their different color temps they offer because that is probably the most important choice when choosing bulbs to get each room in the proper "mood" for the activity. Philips offers depending on bulb time Vintage (2200k), soft white (2700k), bright white (3000k) and daylight (5000k) color temps. Buy a bunch to test, figure out what works, return the ones you don't like.
    If you're super anal with color temp, Philips also makes Hue which has bulbs that can be set to any color, and cheaper Hue whites that can be set to any color temperature. The problem with Hue is that it requires always on power, so you're removing traditional switches, wiring them together and replacing it with Hue switches which talks to the hub. It's a stupid setup but we have 1 room (kids) that way because they like playing with room colors.
    Philips also makes bulbs where you can choose between 3 color temps but those are a waste of money since each room really just needs 1 optimal color temp, so better off just choosing the right temp for the room.
  9. #469
    Feb 2004
    Bavaria
    Model 3 Performance
    Any local places where you can get garage door opener compatible LED bulbs?
  10. #470
    Feb 2003
    Where is the best place to buy Phillips?
    2016 Tesla Model X
    2016 Porsche GT3 RS
  11. #471
    Home Depot.
  12. #472
    Aug 2012
    Crapppy Tire had a sale for $1 each with the SaskPower rebate for their noma A19 led bulbs. Did the whole house in them.
    Had some extras so did some ghetto pie tin keyless lamp holders in the garage until I replaced them with these
  13. #473
    Edmonton, AB
    I use a Phillips in mine and it works fine!
    Changed all my 100w bulbs to 8w Phillips LED Daylight inside/outside of the garage.
    Originally posted by Xtrema
    ZenOps is like everyone's crazy uncle.
    Originally posted by DayGlow
    How do you respond to stupid?
    Jesus fucking christ Rob Anders, learn to read your own links.
    Originally posted by Seth1968
    Zenops: Ok, but remember my dick is made of nickle.
  14. #474
    Dec 2008
    My feit one has been doing fine for about 6 months now
  15. #475
    Feb 2010
    Cochrane
    The NDP just rolled this out
    https://www.efficiencyalberta.ca/
  16. #476
    NW Calgary
    '10 Civic
    You’ll save money and conserve energy—immediately. And the products are yours to keep at no charge!
    What kinds of products are included?
    LED lightbulbs
    LED nightlights
    Faucet aerators
    Low-flow showerheads
    Advanced power strips for audio-visual equipment
    Smart thermostats
    Click here for program details
    When will the program launch?
    Installations will begin in early April 2017, but you can sign up now to be among the first people in your area to get energy-efficient products at no charge.
    thats pretty sweet. Thanks for sending. I signed up.
  17. #477
    Vernon, BC
    2017 Golf TSI
    I hate the Feit bulbs - I changed out about 60 in my house. In the past 14 months I have had over 30 fail. All of them buzz and they seem to be very vulnerable to power dips as they frequently blink off while my other bulbs don't even seem to notice.
    Philips all the way, 4-pack at Home Depot for $7.97 right now. I have some of them that are 3 years old and have had zero failures so far. They don't flash off when the power dips and they don't buzz (or if they do they're quiet enough I don't hear them)
  18. #478
    Has anyone tried out the LED T8 fluorescent tube replacements? I see Home Despot has Phillips, and Costco has Luminus.
    They also have Daylight and Cool White... I wonder which would be better for retrofitting my garage.
  19. #479
    Sep 2003
    Spruce grove, AB
    97 Supra tt
    They have almost the same Lumens & life span. Not worth the money for me.
    751HP HKS V-Pro, Tuned by: Justin Nenni
  20. #480
    MooooooO
    AWD grandpa wagon
    Good thing I saw this. I was going to change the flourscent tubes in my garage to LED over summer. Not gonna happen if it's same lumens and life span.
  1. FS: 1992-1995 civic m3 led mirrors (blue led)*SOLD*
    By 92civic in forum Automotive Parts
    Latest Threads: 11-17-2003, 12:38 AM
  2. Replies: 2
    Latest Threads: 09-16-2003, 11:18 AM
  3. FS: 1157 red led bulbs
    By ExtremeSi in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-12-2003, 03:47 AM
  4. LED bulbs - pics & video
    By FiveFreshFish in forum Cars, Bikes, Machines
    Latest Threads: 12-17-2002, 11:22 AM
  5. Looking to buy clear 194 LED bulbs- any idea's??
    By R-Audi in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-26-2002, 04:29 PM
