How to Check Engine codes on 88 Honda - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: How to Check Engine codes on 88 Honda
    Feb 2003
    85 Fiero
    Default How to Check Engine codes on 88 Honda
    It's a 88 honda civic dx and on deerfoot it throughs on the check engine code, you can smell it running rich but i want to make sure before i start tearing everything apart, how do you access the engine codes.
    Thanks for your help
    Bunch of Honda's
    pull back the carpet on the passenger side floor...... turn key to first click.... watch the flashing led
    Feb 2003
    85 Fiero
    thanks a lot, do you maybe have a link to what all the trouble codes are, it's not my car otherwise i would probably just use a haynes manual but my friend doesn't own one.
    Bunch of Honda's
    yeh give me a minute....
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2 *not all cars*
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor
    65 Secondary oxygen sensor heater
    Feb 2003
    85 Fiero
    actually nevermind i found them. Thanks anyways
    Feb 2003
    85 Fiero
    To late, man you sure know your stuff, thanks again
    Bunch of Honda's
    right, i knew all those off the top of my head
    Feb 2003
    85 Fiero
    didn't think that it just you found them hella fast
    Feb 2003
    85 Fiero
    I've done a lot on this car over the last two days and i can't get over how simplistic it is , i think i might one day buy a hatch back around 90-91. I mean i was able to install a whole stereo on it in 3 hours and then wire some foglights and fix his side markers as well, it would take me forever to find that stuff out in my car. So many damn wires under the dash, the civic was so basic it was almost fun.
    2008 Honda Civic
    5 bux sais he took em from 4thgenerationcivic.com haha, thats where your gonna find the codes...or in any trouble shooting manual for our cars, its really easy. I couldnt have asked for a better "first car" its old enough (insurance, accidents) safe enough (slow) and its so simple to fix
  1. Paint codes?
    By Illusionsir in forum Performance Modifications
    Latest Threads: 07-03-2003, 07:52 AM
  2. Honda Chassis codes
    By Ferio_vti in forum General Car/Bike Talk
    Latest Threads: 06-12-2003, 07:34 AM
  3. WTD Immediately - links to gunmetal paint or paint codes
    Latest Threads: 05-30-2003, 12:52 PM
  4. Chassis Codes
    By lammer in forum General Car/Bike Talk
    Latest Threads: 05-11-2003, 12:07 AM
  5. Complete Honda Engine Codes and Specs
    By davidI in forum General Car/Bike Talk
    Latest Threads: 04-01-2003, 11:11 PM
