For 2 Door vehicles. Can be used with a keyless entry system. Will unlock both doors when you unlock one door. $50
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
So its just basically power door locks rite?? Will it work in my Civic??
yes, it will.
This is a universal kit which you may install in any car. It's pretty simple to install, just bolt actuator to door, look at your lock rod, and mount this rod hooked up to the actuator. and then just give it some power from your fuse panel. There is one wire for unlock input, and one for lock input, very easy to hook up to any alarm or keyless entry system.
abguy pretty much summed it up. The added feature is the central processor that allows both doors to unlock/lock when you unlock one door (if you want to do that).
To avoid any confusion, this kit will add power door locks to a car that does not have any power door locks installed. It will work with any alarm that has a keyless entry button.
