Good BMW Mechanics - Page 4 - Beyond.ca - Car Forums
Page 4 of 5 FirstFirst ... 3 4 5 LastLast
Results 61 to 80 of 88
Thread: Good BMW Mechanics
  1. #61
    Not the NE
    ‘Berta Special
    Personally i think its a design flaw for cold climates, battery is in the floor of the trunk so it literally never thaws in the winter unless you park it in a heated parkade. No shit the battery isn't going to charge properly at -25C and will degrade quickly. At least most cars the engine heat thaws it out a bit so it can build a charge while you drive.
    Though it has admittedly never actually not started.
  2. #62
    Jun 2008
    After owning my X5 for two years (and selling it a few months ago, thankfully) I'll never buy another bmw. I'd rather drive something based completely on reliability.
  3. #63
    FK8, DC2R, Outback XT
    Do you throw your car on a tender while its parked in your garage?
  4. #64
    Not the NE
    ‘Berta Special
    I do not, but I should. Especially now that I have a new battery.
    I DD it so it isn't usually an issue. But below -20 or so I start getting the nasty messages.
  5. #65
    Online
    Budget Baller
    Originally posted by rx7boi
    Damn
    I was actually looking at some 328i as well.
    Time to buy a civic and live the regular life.......lol
    lol that's my plan to live the regular life now. It was fun while it lasted.
    We have next gen Beyond Ballers to step up.
    Quote Originally Posted by max_boost View Post
    In Beyond We Trust
  6. #66
    Oct 2011
    TL SHAWD,Camaro SS
    Is that for weight dist? Or just to be funky and German?
  7. #67
    Not the NE
    ‘Berta Special
    I think so. Also makes room in engine bay. No spare back there so it's an easy relocation. Still think it's not a bright idea.
  8. #68
    Jun 2015
    Edmonton
    LNF
    It is for weight distribution.. Lots of american cars have the battery in the trunk. I have two cars (GM) with the batteries in the trunk and neither of them have specific issues related to the battery being in the trunk. In fact, it is easier to access the battery if i need to replace it.
  9. #69
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    Not to call anyone out, but BMW places the battery in the rear right wheel well area for Weight distribution.
    A charged battery can also go to -70c, and only to -10c completely discharged before it fully freezes.
    BMW batteries don't last very long due to the nature of the BMW control modules power consumption.
    A car sitting with the key in and engine off, can draw as much as 40 amps, this in turn causes harsh charge and discharge cycles which leads to plate sulphation, and dramatically reduces its life.
    For comparison most cars draw about 30-35 amps while running, in those instances the alternator takes care of the electrical load, and allows the battery to act a buffer.
    BMW modules all act like mini computers, they all have their own processor, and programmed lines of logic. Each module may draw up to 2 amps of power, but being that some BMW cars have over 100 individual modules, the power consumption really adds up.
    Almost all other automobiles modules work off an eprrom logic chip, which uses far less power.
    One of things you can do to increase battery life in a Beemer is to buy the biggest battery available for the car, and also make sure its an AGM.
    Some cars are starting to come with NiFe Batteries, but require its own charge control, and are pretty expensive.
    Ford was also shipping out Li-ion batteries on some of the transits as well, but because of shipping regulations, you can't buy them form the dealer.
    It was mentioned, but it is a really good idea to use a trickle charger overnight, and especially if you don't plan to use you vehicle for a few days.
  10. #70
    Not the NE
    ‘Berta Special
    Yea mines a giant AGM. New M3/4 are LiIon if I remember correctly.
    I know I should use a charger at least in the cold. Will look into picking up one of the new CTeK ones (which the BMW charger is just a rebrand of).
    It helps that I don't use the start stop function but the alternator still decouples a ton on these efficient dynamics cars.
  11. #71
    Oct 2003
    GLA
    Not making a case for modern BMWs here. Given the advancements that competitors have made in the markeplace on BMW in recent years (ATS-V vs M cars, for instance), a lot of this stuff is inexcusable.
    A wise man once told me to never knock another man's hustle. I usually extend that to not knocking other peoples' cars. But...
    Also, the weight distribution thing: our GL350 also hs the battery in the back. And that thing is so heavy you could probably sit a water buffalo on the hood and not make an appreciable difference in distribution. (Also, if these batteries are so heavy, then I would think that putting on on the SIDE in the back would also cause issues.) I think it's probably more of a packaging thing. How much do the cables weight to get the connection up front, anyway?
  12. #72
    Oct 2002
    One of the biggest selling points of performance for Beemers is a perfect or near perfect 50/50 weight distribution. All BMWs are built around this feature.
    I personally don't see the power consumption of these cars as a crutch, the newer electronics in them are very intelligent and do much more than the consumer is aware of. I think the fault lies in current battery technology, these cars would also benefit from regenative braking, but the cost to add that would make it an unfavourable option.
    The cable that runs from the back to the distribution block weighs less than 5lbs,
  13. #73
    Not the NE
    ‘Berta Special
    New battery already throwing a discharge code lmao. Even after driving it around for a couple hours. BMW's loss, free battery for me. Its just too cold to get perfect voltage.
  14. #74
    Oct 2002
    Has BMW done a full Energy Diagnosis?
    At this point I would be asking BMW to calibrate the energy management system, then take it for a 45 drive.
    Or diagnose the faulty sensor which measures battery amperage/use.
    Also have you allowed the car to sit for more than 8-12 hours for the battery management to self calibrate?
  15. #75
    When I had my M3, I lost a battery after a year of owning the car (increased discharge etc etc) and after I replaced it with a new AGM unit and bought a $60 Noco Genius charger from Crappy Tire. I threw the car on the trickle charger every night even if I was planning to drive the car the next day. Had the car for 3 more years and didnt have any issues after that.
    Best $60 I spent.
    Do you also lock your doors when you park the car in the garage? If you keep it unlocked, you'll drain the battery as the car will never go into "sleep mode"
  16. #76
    Not the NE
    ‘Berta Special
    Car always locked so no worries there. And nope i did not let the car sit for 8-12 hours lol, i picked it up[ at 5 and drove it around for a couple hours with a few on-off's. Between the new battery and the new fuel pump smoothest starts it has had since i bought it.
    No full energy diagnosis either. I don't think there is anything wrong with the car tbh, just flashes an increased battery discharge warning when i turn the car on or off then it goes about its business as if nothing is wrong.
    Heck I only mentioned the battery to my SA in passing as i threw the keys at him for routine maintenance this morning.
    It's going back in in April for an oil change anyways ( system wouldn't leet them do it today under inclusive maintenance lol ) so if its still flashing at me then I'll bring it up.
    The other elephant in the room with my battery is that i have only put 26k km on it in 36 months. Short commutes.
  17. #77
    Oct 2002
    lol okay... a trickle charger is a must for your cars driving patterns...
    If it's any consolation, all cars from all manufacturers would suffer the same faults if it was driven 8500kms per year.
  18. #78
    Not the NE
    ‘Berta Special
    Again, i was never convinced there was anything wrong.
  19. #79
    Oct 2011
    TL SHAWD,Camaro SS
    Seems that most German cars @ work (Merc or BMW) run a trickle charger if they sit for more than a couple of days. It sounds silly, but better than waking up to a dead das auto.
  20. #80
    Not the NE
    ‘Berta Special
    Got to pay to play, if I want to be able to email google maps directions to my car from my phone I guess something needs to be staying awake in there
    I just ordered a ctek 4.3. Been wanting a charger for ages and this seems like as good an excuse as any to get one. This battery will outlast the ownership of the car at least.
    Watch now my next car will have a lithium battery and I'll need a new charger lmao.
  1. Any Good BMW Certified Backyard Mechanics
    By import_rider in forum Alberta BMW Owners Club
    Latest Threads: 08-11-2006, 10:02 PM
  2. Any Good BMW Mechanics?
    By BMPnRIDE in forum Alberta BMW Owners Club
    Latest Threads: 02-03-2006, 04:27 AM
  3. Good Lethbridge Mechanics???
    By maximus in forum General Car/Bike Talk
    Latest Threads: 04-12-2004, 12:13 AM
  4. Good source for learning Fluid Mechanics?
    By Super_Geo in forum Campus Chat
    Latest Threads: 02-02-2004, 07:45 PM
  5. Good BMW mechanics in Calgary
    By BMPnRIDE in forum Mechanical
    Latest Threads: 01-29-2004, 03:08 AM
