Lock Pick's in Canada - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Lock Pick's in Canada
    Apr 2005
    05 Outback 2.5xt
    Default Lock Pick's in Canada
    Does anyone know if it's illegal to own lock pick's in canada? I want to try it as a hobby, but just curious if its illegal to own the tools. I dont plan on carrying them around with me... couldn't find anything online.
    These guys specifically
    http://www.lockpicks.com/index.asp?P...rodID=502&HS=1
    Edit: Found it...
    Restricted keys and locksmith's instruments
    26 (1) In this section, "authorized person" means a person who
    (a) holds a valid security business licence authorizing him or her to carry on the business of a locksmith,
    (b) holds a valid security employee licence and is employed as a locksmith by a person referred to in paragraph (a),
    (c) is a locksmith who is exempt from sections 3 and 10 by virtue of section 2 (f),
    (d) is designated by the regulations as an authorized person for the purposes of this section, or
    (e) is authorized in writing by the registrar to do a thing that this section otherwise prohibits.
    (2) In giving an authorization under subsection (1) (e), the registrar may impose conditions the registrar considers appropriate, and the registrar may, if he or she considers it appropriate, cancel an authorization he or she has given.
    (3) A person must not cut or make a restricted key, or transfer possession of, lend or otherwise provide a restricted key to another person unless the person cutting, making, transferring, lending or providing the key is
    (a) an authorized person, or
    (b) the owner of the lock that is to be operated by the key or is an employee of the owner of the lock that is to be operated by the key and is acting with the authority of the owner.
    (4) A person, other than an authorized person, must not have in his or her possession
    (a) a key, pick, rocker key or vibrating pick tool, or
    (b) any instrument
    that is designed or adapted to open a lock without using the proper key or combination or to bypass a lock.
    Oct 2004
    AB/NS
    I had this idea when I was younger.. 14 or so.. I sent away for some learn at home package, or something of the sort.. to this day they still send crap to my parents house.. haha..
    I actually made a couple little tools, there's lots of info online, if you dig around.. I used to practice on my gun cabinet lock and got so good at how it felt, I could easily do it in 3-5seconds..
    Winnipeg, Manitoba
    You can make your own out of spring steel just make a torque wrench and some rakes with different heads (which pictures are easy to find online) Not hard at all.
    I might be furious but I'm not fast.
    Winnipeg, Manitoba
    http://www.wikihow.com/Pick-a-Lock
    Tension wrench (Many common objects can be used as a tension wrench, provided that they are strong enough to apply pressure to the cylinder and thin enough to just barely fit in the end of the keyhole (you donít need or want the wrench to be so thin that it goes all the way in the keyhole). The tension wrench should also be small enough to afford you plenty of room to maneuver the pick when they are both in the keyhole. You can use a small allen wrench that you file down at the end or you can just use a thin-tipped flathead screwdriver.)
    Pick(s) (You can use a safety pin or a paperclip. To make a pick from a paperclip, straighten the paperclip and then bend it 90 degrees very close to one end. Alternately, you may bend one end into a tiny loop. Needle-nose pliers make bending the paperclip much easier. Make sure whatever you choose for a pick is sturdy, or you will not be able to apply enough pressure to push the lockís pins up without your pick bending.)
    Aug 2003
    City:Calgary State:Omnipresent
    AE92GZE, Legacy BL, Yaris
    Lockpicks are obsolete.
    Wanna see why I am installing an alarm on the house this week, and changing all the locks to a bump proof style?
    Do a search on youtube for "bumpkey"
    They are tough to get but way better than the homemade ones, a set of southord's are top notch.
    And yes, they make a killer hobby.
    Winnipeg, Manitoba
    Wanna see why I am installing an alarm on the house this week, and changing all the locks bo a bump proof style?
    Make sure it's not a wireless alarm. I pissed off the ADT guy when I hacked his alarm system in under 5 mins by scrambling the codes it sends wirelessly.
    Feb 2004
    honda with fart can
    I made all my own All you need is a few hack saw blades, a dremel tool and a few allen wrenches.
    Aug 2003
    No phone I'm making bars for the basement windows (basement unfinished)
    + installing a motion sensor down there just in case so it trips b4 the phone cord can get cut.
    If someone 'really' wants to get in they will no matter what you do but with bump keys there is no sign of forced entry and a lot of insurance companies are accusing victims of fraud, and they are so 'f'n easy to make and use @#$%. All i'm trying to do is make it hard enough they'll go elsewhere.
    Nov 2004
    Cal - DIGIT
    CS-GA20DE-TT // B5 A4 TT
    just looked up bumpkeys and holy shit.
    I am buying a 2x4 for the door... and beside my bed.
    yup,.. me too!
    Winnipeg, Manitoba
    I never lock my doors so bump keys don't work on my house
  1. Buying a car from Eastern Canada and bringing it to Western Canada
    By JustinGTP in forum General Car/Bike Talk
    Latest Threads: 03-19-2007, 07:50 PM
  2. Replies: 10
    Latest Threads: 05-05-2003, 06:38 PM
  3. Door Lock
    By Ajay in forum Mechanical
    Latest Threads: 12-03-2002, 03:04 PM
  4. door lock is focked
    By GTS Jeff in forum Mechanical
    Latest Threads: 11-15-2002, 02:28 AM
  5. Power Door Lock Kit
    By Weapon_R in forum Mechanical
    Latest Threads: 09-26-2002, 04:33 PM
