tire pressure arument, help - Beyond.ca - Car Forums
Results 1 to 20 of 40
Thread: tire pressure arument, help
    Mar 2007
    98 Integra GSR
    Default tire pressure arument, help
    What do you guys think, assuming you are running stock size on a car, should the tires be filled with the psi that is printed in the doorsill, or close to the psi that is printed on the sidewall?
    957,958,NC1,NC3,E90,ITR
    doesn't matter what size tires you always use the one on doorsill
    Dec 2003
    German
    Doorsill.
    Dec 2006
    Lease
    Doorsill
    oreo cookie
    a wrx.
    Chalk your tires and adjust pressure until all the tread is used but none of the sidewall is being scrubbed.
    Victoria, BC
    '97 BMW 328is M-Sport
    Doorsill. I had my tires put on at the Tire Warehouse, turns out they put 35 psi in the tire off the car (doorsill), which translated into about 50 psi ON the car. No wonder the stupid thing took every bump like the rubber was solid. Fixed now
    Originally posted by FraserB
    I think their main complaint is that they did not receive the stolen property they paid for.
    oreo cookie
    a wrx.
    Where did the 15 PSI come from?
    the weight of the car
    Mar 2007
    98 Integra GSR
    So why does everyone say the doorsill, at that psi all tires that i have seen look flat and get the rubbing on the sidewall, especially aftermarket rubber, like on my teg. The doorsill calls for like 35 and the nexen rubber say 50, at 35 they are basically flat and trashed the sidewall...?? anyone else have these issues?
    even my g/f's optra's tires have scrubbing on the sidewall and look flat from 32 psi, but the rubber says max 44?
    the weight of the car has nothing to do with it. the volume of the tire never changes so the pressure inside always stays the same. the shape may change but the volume does not.
    maybe your gauge is broken.
    Dec 2006
    Lease
    Yea, fill ur gf's Optra tires with 44psi we're all wrong.
    Seriously, it might be different with aftermarket or when you change the tire size (and profile of tires in return)...
    If I'm reading OP correctly, he/she was just trying to find out how to fill original tire PSI as a maintenance measure. And most of our answer are from the vehicle's door sticker. The Max. psi on the tire is only a warning of what the tire shouldn't be exceeded on, which might or might not blow up in your face.
    it doesn't matter what tire it is or what size the tire is, you should always fill it to the doorsill specs.
    Dec 2006
    Lease
    never heard of anyone running at 50 psi on a passenger car
    May 2005
    I run 48psi on my azenis, but only on the track. Use whatever it says on your doorsill for the street.
    Dec 2006
    Lease
    Edit: As per answering to OP, I got the impression we're talking about regular street driving use. (he/she was saying something about filling STOCK tires)
    Don't wanna make the impression I'm don't know much.
    well i run my radials at 12 psi for drag racing but that doesn't mean the op should, lol.
    oreo cookie
    a wrx.
    Uhh no.
    T2S
    pedals
    the rating on the tire is the MAX pressure for the tire, not the recommended pressure
    Mr. Forex technical
    a tank
    hmm I also notice a change in PSI number before and after car is driven with. So its best to measure after a car has not been driven over night.
    As far as the doorsill goes, that is what I do, my acura calls for 32 psi in the front and 31 in the rear I believe. however I do notice the tires look kinda flat (like it doesnt have enough PSI or something), im assuming this is normal?
    _________
    2019 IS350 AWD
    20xx NX350 AWD
    Victoria, BC
    Alright, let's look at some basic pressure calcs for a second here:
    Pressure = force/area
    pressure = B x (V1/v2) where B= bulk modulus (constant), V1 is the initial volume and V2 is the final volume.
    However, by looking at a tire on a car and the same tire OFF a car, it is easy to conclude that the weight of the car has compressed the tire at the bottom. Now, the tire DOES expand, but it doesn't expand the same amount as the air ( or whatever gas you've put in). Therefore, the final volume is smaller than the initial volume, which would result in a pressure increase.
    It might help to think of it this way: if you lean on a balloon, why does it eventually pop? The air inside is compressing, but the balloon doesn't want to expand at the same rate the air does at any point along its expansion curve. Once the increase in pressure is too much, the balloon breaks.
    The moral of the story is to pump the tire to the doorsill pressure off the car, and once installed, adjust accordingly.
  1. FS: Spoon pressure plate, Spoon organic disc, Spoon pressure plate
    By redx2nv in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 06-15-2004, 08:49 PM
  2. Tire pressure question..
    By Ashkente in forum Mechanical
    Latest Threads: 11-02-2003, 07:39 PM
  3. Tire pressure
    By YCB in forum Performance Modifications
    Latest Threads: 11-30-2002, 10:00 AM
  4. tire pressure
    By evylgrynn in forum Performance Modifications
    Latest Threads: 10-14-2002, 07:50 PM
  5. What tire pressure should I go with? (Parada Spec-2)
    By REdOX in forum Performance Modifications
    Latest Threads: 09-02-2002, 07:20 AM
