Re: Trouble Pushing
Originally posted by beecue
so I started to work out a couple of weeks ago .. the problem I am having is after I do a couple of exercises I am pretty much done .. when I try to do other ones I can't push more than 4-5 reps and it won't be at a high weight .. I usually take 30sec between sets .. is that enough? ... also what should I be doing to increase strength because it doesn't seem like I am lifting more pounds than the previous week
If you want strength rest 3 minutes a set for the big lifts (bench, Deads, Squats).
As a n00b you should be able to increase on the big 3 by 2-4lbs a week. It sounds to me like you're overtraining and possibly not into it mentally yet. That will come in time, Intensity is the key in the gym.
Also just so you know, you don't really get strong in the gym. You must adapt proper sleeping patterns and eat! Post workout 65G protein with 30G fast carbs, 30G slow carbs and then a low GI meal an hour later with 50more G of protein.
But hell forget most of the routines out there, the main thigns to focus as a real beginner are these excersizes: Dips, Pullups, Squats, Deadlifts, Bench, Rows, Leg press, and goodmornings. Focus on COmpound movements and don't worry about specializing yet. Good luck
-H.P. Lovecraft
