Four new tires were installed (on October 17/2007), and were balanced. These VERY high quality Yokohoma's were installed .
- Rear windshield wiper motor and blade were replaced and work perfect (installed on October 17/2007).
- New front brake pads and rotors and flush braking system fluid, front Differential pinion seal and Front struts were replaced on October 22/2007.
- New rear sway bar bushing's and clamps were also replaced.
- New upper radiator hose, clamps, and all new coolant was installed (installed on October 17/2007).
- New Mass Airflow Sensor assembly ($590) installed on October 17/2007)
- Undercoat and rust-proof lining was fully installed throughout (installed on October 17/2007).
- Misc maintenance including all new bulbs throughout, new wiper blades, new spark plugs, new fuel filters, new clamps, new battery, new Antenna mast, etc.
- Transfer case and all fluids were changed (installed on October 17/2007).
- All fluids were topped up, air filter was changed, an oil change and transmission flush were completed, and all spark plugs were replaced (occurred on October 17/2007).
- The intake air system and full exhaust system were completely rehauled and cleaned for better gas mileage and for the engine to breathe properly (installed on October 17/2007). This QX4 also went to a muffler shop for a Back Pressure Exhaust test on October 18/2007.
- New headlight bulbs and fogs were installed recently (in September).
- New window tint was installed in the summer.
This SUV runs perfect in 4x4 and 4x2. Every option on this vehicle works.
Maintenance has been done on this car meticulously throughout the duration of its life, and it drives like a new SUV. Be prepared for the winter! With all the recent work, this SUV will not need any work for the upcoming winter, whatsoever, maintenance that has been done is above and beyond what is expected.
I HAVE ALL RECEIPTS FOR THE WORK COMPLETED.
