Like Rage said... Mohawk.Husky 94 easily typically allows 2 psi more boost over anything else.
As for mileage..... I can't see how it would change. AT WORST, you might see a 3.5% drop.... but that's not likely since its more volatile and you get better, more complete burn........
The way I see it.... you either have a car that just need premium, in which case, use whatever is cheapest. If its hot rodded and tuned to the max, then you have only one choice, the 94....
For the Original poster.... if its a newer factory Legacy GT.... it doesn't matter what premium you run.
