here is the new album...
http://www.muchmusic.com/music/firstspin/daftpunk/
live streaming, so you can't download it...or can you???
Fucking awesome CD... I downloaded their set from Coachella off the net which was suppose to be their released album. They decided that the quality of the recording on the net was so good that they would release a different set.
Both Coachella and Alive are similar but different at the same time.... so good
so is coachella exactly the same as this? if so...i'll BRB.Originally posted by 88CRX
Nope, they are the same set list or a very simalar set list but lots of the song transitions are different. I've burnt both and have been listening to both.Originally posted by urbannomad
AND Daft Punk completely supports the file sharing of Coachella from what I've read
any other sources for streaming, much music isn't working for me
Coachella is here:
http://rawkblog.blogspot.com/2007/09...006-42906.html
no NSFW issues with that site?
cheers! but it's all one file! thanks again.
nope. its good. just a music blog.Originally posted by finboy
Screw downloading it
Im buying it.
I love Daft Punk
On group i have no problem shelling cash out for.
Its also on mtv.ca under music, the leak
sick cd!!! daft punk FTW!
That is a balling set up
THE MAKING OF…THE DAFT PUNK HELMETS
These helmets were commissioned by the punk band Daft Punk for a music video. Over the years, LED Effects has received many inquiries from people who wanted to purchase their own helmet. Unfortunately, these helmets are custom designed stage props and cost over $14,000. While the helmets are reasonably simple in design, the cost of labor and materials make it impractical to mass produce and market them. In addition, Daft
Punk owns the copyright and concept rights to the helmets, so there may be additional licensing fees to pay. In short, yes, we can build you a helmet, but it will cost you thousands of dollars and take a year to produce. Here is how the helmets were made:
1. A model shop cast the face of the musician. This was used to create a bust which was
used as a template for the design.
2. The next step was to modify a motorcycle helmet. The body was cut away to allow for
cables and electronics. Two pin holes were provided so the wearer could see out.
3. Clay models were created for all the unique parts. This included a back pack and an arm
band controller.
4. Electronic displays were designed using prototype PC board materials.
5. The LED display panels were assembled by placing each LED one-by-one into a plastic
sheet and glued into place. Each LED required three feet of wiring to connect it to power
and control circuitry. The finished panel was bolted to the helmet frame.
6. The LED cabling was routed around the “ears” of the helmet and out the back. The
helmet cables led down to the backpack where the main controller board was located.
7. The system was originally powered by batteries, but this was later switched over to a
power cord system.
8. The control keypad on the armband was a custom manufactured PC board.
9. Exterior plastic molding and finishing materials were custom manufactured by a special
effects studio to complete the helmet. Once these pieces were added, the helmet details
were touched up with paint.
The helmets were used to produce a music video. As far as we are aware, the units are
still in use for performances.
very nice. hopefully that kanye west track is not on it...
HUH?...Originally posted by rmk
this is sick, thanks for posting the leak!
This album is AWESOME!! Time to go buy it!!
is it out yet?
Ummm.........Daft Punk released Harder, Better, Faster, Stronger before Kanye used the SAMPLE in his song Stronger.Originally posted by rmk
December 4th.Originally posted by LUCKYSTRIKE
is it out yet?
Sweet i love Daft Punk. Gonna get this for sure.
Member since 2003.
It's just a live CD then?
