FS: bunch of great computer stuffs - Beyond.ca - Car Forums
Results 1 to 18 of 18
Thread: FS: bunch of great computer stuffs
    Jul 2005
    Calgary Alberta
    93 Ford Flareside 4x4 9"lift
    Default FS: bunch of great computer stuffs
    All thats left of the bunch!
    FS: Sapphire HD2600XT quote:
    ATI RADEON™ HD 2600XT 512mb gddr3 pci-e dual DVI TV out Has HDMI out adaptor.
    $100 obo
    GeForce 8500 GT HDMI
    NVIDIA GeForce 8500 GT graphics card with 512MB dedicated video memory HDMI out DVI Svideo
    $60 OBO! Sold!
    Pm me if your wanting anything
    Nov 2003
    2017 370Z / 2008 Sentra
    Do you know the processor "Stepping"?
    Jul 2005
    Calgary Alberta
    Hmm a little overclocking friendly eh! Yes it is the much desired SLACR stepping... Yes these chips are able to run at 3800mhz + speeds.
    I myself am not an overclocker anymore and am just wanting quiet I have an E6850 and im perfectly happy with it and its running at 26c with the watercooling right now!
    Jul 2005
    Calgary Alberta
    Bump for a new processor for sale!
    Jul 2005
    Calgary Alberta
    Default FS: Sapphire HD2600XT
    390 million transistors on 65nm fabrication process
    128-bit DDR2/GDDR3/GDDR4 memory interface
    Ring Bus Memory Controller
    Fully distributed design with 256-bit internal ring bus for memory reads and writes
    Unified Superscalar Shader Architecture
    120 stream processing units
    Dynamic load balancing and resource allocation for vertex, geometry, and pixel shaders
    Common instruction set and texture unit access supported for all types of shaders
    Dedicated branch execution units and texture address processors
    128-bit floating point precision for all operations
    Command processor for reduced CPU overhead
    Shader instruction and constant caches
    Up to 40 texture fetches per clock cycle
    Up to 128 textures per pixel
    Fully associative multi-level texture cache design
    DXTC and 3Dc+ texture compression
    High resolution texture support (up to 8192 x 8192)
    Fully associative texture Z/stencil cache designs
    Double-sided hierarchical Z/stencil buffer
    Early Z test, Re-Z, Z Range optimization, and Fast Z Clear
    Lossless Z & stencil compression (up to 128:1)
    Lossless color compression (up to 8:1)
    8 render targets (MRTs) with anti-aliasing support
    Physics processing support
    Full support for Microsoft® DirectX® 10.0
    Shader Model 4.0
    Geometry Shaders
    Stream Output
    Integer and Bitwise Operations
    Alpha to Coverage
    Constant Buffers
    State Objects
    Texture Arrays
    Dynamic Geometry Acceleration
    High performance vertex cache
    Programmable tessellation unit
    Accelerated geometry shader path for geometry amplification
    Memory read/write cache for improved stream output performance
    Anti-aliasing features
    Multi-sample anti-aliasing (up to 8 samples per pixel)
    Up to 24x Custom Filter Anti-Aliasing (CFAA) for improved quality
    Adaptive super-sampling and multi-sampling
    Temporal anti-aliasing
    Gamma correct
    Super AA (CrossFire configurations only)
    All anti-aliasing features compatible with HDR rendering
    Texture filtering features
    2x/4x/8x/16x high quality adaptive anisotropic filtering modes (up to 128 taps per pixel)
    128-bit floating point HDR texture filtering
    Bicubic filtering
    sRGB filtering (gamma/degamma)
    Percentage Closer Filtering (PCF)
    Depth & stencil texture (DST) format support
    Shared exponent HDR (RGBE 9:9:9:5) texture format support
    CrossFire™ Multi-GPU Technology
    Scale up rendering performance and image quality with 2 or more GPUs
    Integrated compositing engine
    High performance dual channel interconnect
    ATI Avivo™ HD Video and Display Platform
    Dedicated unified video decoder (UVD) for H.264/AVC and VC-1 video formats
    High definition (HD) playback of both Blu-ray and HD DVD formats
    Hardware MPEG-1, MPEG-2, MPEG-4/DivX video decode acceleration
    Motion compensation and iDCT (inverse discrete cosine transform)
    Avivo Video Post Processor
    Color space conversion
    Chroma subsampling format conversion
    Horizontal and vertical scaling
    Gamma correction
    High Quality Video Post Processing
    Advanced vector adaptive per-pixel de-interlacing
    De-blocking and noise reduction filtering
    Detail enhancement
    Inverse telecine (2:2 and 3:2 pull-down correction)
    Bad edit correction
    Two independent display controllers
    Drive two displays simultaneously with independent resolutions, refresh rates, color controls and video overlays for each display
    Full 30-bit display processing
    Programmable piecewise linear gamma correction, color correction, and color space conversion
    Spatial/temporal dithering provides 30-bit color quality on 24-bit and 18-bit displays
    High quality pre- and post-scaling engines, with underscan support for all display outputs
    Content-adaptive de-flicker filtering for interlaced displays
    Fast, glitch-free mode switching
    Hardware cursor
    Two integrated dual-link DVI display outputs
    Each supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
    Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
    Two integrated 400 MHz 30-bit RAMDACs
    Each supports analog displays connected by VGA at all resolutions up to 2048x15361
    HDMI output support
    Supports all display resolutions up to 1920x10801
    Integrated HD audio controller with multi-channel (5.1) AC3 support, enabling a plug-and-play cable-less audio solution
    Integrated AMD Xilleon™ HDTV encoder
    Provides high quality analog TV output (component/S-video/composite)
    Supports SDTV and HDTV resolutions
    Underscan and overscan compensation
    MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
    Seamless integration of pixel shaders with video in real time
    VGA mode support on all display outputs
    PCI Express x16 bus interface
    OpenGL 2.0 support
    $100 OBO
    Nov 2005
    Oh man i was just wanting to buy one but AGP version, i woulda been soooo all over that
    Aug 2004
    Whats the interface on the geforce 8500 ?
    2011 Ram 1500 QC Sport
    Jul 2005
    Calgary Alberta
    Its a Pci-e card
    Sep 2003
    2018 Allroad, 2019 Sierra Denali
    good stepping on the cpu, gl with sale
    Jul 2005
    Calgary Alberta
    Updated for sold stuff and thanks for the kind words npham!
    Jul 2005
    Calgary Alberta
    New Prices!
    Jul 2005
    Calgary Alberta
    Price updated
    Jul 2005
    Calgary Alberta
    updated
    Jul 2005
    Calgary Alberta
    bump
    Jul 2005
    Calgary Alberta
    bump
    Jul 2005
    Calgary Alberta
    Updated prices on the video cards.
    Jul 2005
    Calgary Alberta
    bump
    Jun 2005
    check pm please! thanks
  1. FS: Computer Stuffs
    By armae in forum Computer Hardware & Peripherals
    Latest Threads: 04-15-2007, 02:17 AM
  2. How much cushom I have to pay if buying computer stuffs from US to Cananda
    By mucat in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-17-2007, 05:34 PM
  3. Free: really old computer stuffs
    By mucat in forum Computer Hardware & Peripherals
    Latest Threads: 09-15-2006, 01:27 PM
  4. FS: Misc computer stuffs and system
    By Alexs in forum Computer Hardware & Peripherals
    Latest Threads: 10-27-2005, 10:53 PM
  5. FS: Bunch of Bunch of STUFF
    By toyboy88 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-05-2004, 09:12 PM
