FS: Apple 17' G4 PowerBook Sealed -- Brand New! - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: FS: Apple 17' G4 PowerBook Sealed -- Brand New!
    Aug 2002
    Default FS: Apple 17' G4 PowerBook Sealed -- Brand New!
    Brand new, sealed G4 PowerBook (Mac).
    MSRP: $4,699.00 w/o tax
    Just gauging interest, might keep it for myself. Make an offer.
    All reciepts are available and comes with a 3 year warrenty.
    Specs:
    1GHz PowerPC G4, 256K SRAM Level 2 cache, 1MB DDR SRAM Level 3 cache, 512MB PC2700 DDR SDRAM, 17-inch (diagonal), 1440x900 resolution, TFT widescreen, NVIDIA GeForce4 440 Go with 64MB of DDR SDRAM, 60GB Ultra ATA/100, Slot-loading SuperDrive (DVD-R/CD-RW), Built-in Bluetooth 1.1; built-in AirPort Extreme card, Mac OS X v10.2 Jaguar
    Megawide 17-inch display
    It’s the first thing you’ll notice about the world’s first notebook computer with a 17-inch display, the largest ever in a notebook. When open, it’s vast. This PowerBook’s breathtaking display offers the same viewing area as a 19-inch CRT monitor. You’ll love the amount of information you can see on the screen at one time. It supports a resolution of 1440-by-900 pixels — an eye-popping 1.3 million pixels appearing on the screen simultaneously, with room aplenty for your menus, toolbars and palettes.
    Futuristic backlit keyboard with ambient light sensor
    Another first from Apple featured on the new 17-inch PowerBook G4: a unique fiber optic backlit keyboard with laser-etched keys that’s right out of the future. A light sensor automatically adjusts the keyboard and screen brightness based on the available ambient light. In low light, for example, the PowerBook G4 automatically lowers its display backlight and turns on the backlit keyboard. Then light-emitting fiber optic strands located under the keyboard come to life and illuminate the backlit keyboard so you can continue to work, unaffected by the change in ambient light.
    The legendary SuperDrive
    Your PowerBook G4 with SuperDrive (DVD-R/CD-RW) comes loaded with iDVD software, and can be used to burn DVDs which can be played in most consumer DVD players. The SuperDrive also lets you use iTunes to burn your own music CDs, and the Disc Burner feature in Mac OS X to burn data CDs. The SuperDrive reads DVD titles at 8x, and writes to 4.7-gigabyte DVD-R discs at 1x.
    Fast FireWire 800
    With more than 30 times the bandwidth of the popular USB peripheral standard, FireWire 400 has become the gold standard for high-speed data transfer. And now Apple has upped the ante yet again, effectively doubling data throughput with FireWire 800. The new 17-inch PowerBook G4 has two FireWire ports — one for the hundreds of FireWire 400 peripherals already available, and the other for the coming generation of FireWire 800 peripherals.
    54Mbps AirPort Extreme — up to 5 times faster
    The new 17-inch PowerBook G4 features the hot new 802.11g AirPort Extreme technology — at 54Mbps, the fastest wireless connection available on a Mac. The 17-inch PowerBook G4 comes with AirPort Extreme installed. And since AirPort Extreme is backward-compatible with 802.11b networks — and with thousands of wireless “hot spots” in hotels, airport lounges, coffee shops and bookstores around the world — you’ll be able to use your PowerBook G4 to get online from practically anywhere.
    Sync with Bluetooth
    Bluetooth is built-in to the new 17-inch PowerBook G4 model. Like AirPort Extreme, Bluetooth connects digital devices wirelessly. Operating within a much shorter range than AirPort, it enables high-speed wireless data transfers between a rapidly growing list of Bluetooth-savvy products. Using iSync, for instance, you can use Bluetooth to synchronize your personal information between your PowerBook, your mobile phone and your Palm OS-based handheld. And Bluetooth lets you take advantage of GPRS connectivity to check your email from anywhere — a benefit that comes in handy on those occasions when a 802.11 wireless hotspot isn’t available.
    Leading-edge industrial design
    You’ll love the high-resolution 17-inch active-matrix display with brilliant 1440-by-900-pixel resolution. And you’ll marvel at the way we’ve fitted this supersharp display into such a remarkably small frame — just 15.4 inches wide, 10.2 inches deep, 1.0 inches thin and weighing a mere 6.8 pounds. Housed in a lightweight and durable aluminum alloy enclosure, the new 17-inch PowerBook G4 is resistant to stains and scratches. It also features an all-new, drop-dead gorgeous design — perfectly smooth on all surfaces, with no doors, protruding latches or levers to break, no external buttons to accidentally press, and no sharp edges to catch on your clothing.
    High-speed architecture
    The 1GHz processor on the 17-inch PowerBook G4 gives a tremendous performance boost with an advanced cache memory architecture that provides ultrafast dedicated memory with massively enhanced throughput. The 17-inch PowerBook G4 features 256K backside level 2 cache and 1MB of L3 cache. Accessing data from main memory is significantly faster than accessing data from the hard drive, but L3 cache — which boosts processor function by providing phenomenally fast access to data and application software code — gives this PowerBook G4 an even faster level of memory. The 17-inch PowerBook G4 comes with 512MB of DDR SDRAM. And that’s expandable to 1GB of RAM — allowing you to run several RAM-hungry applications simultaneously, or to store an entire graphics project in main memory for fast image manipulations.
    Lightning-fast graphics
    The new 17-inch PowerBook G4 ships with the NVIDIA GeForce4 440 Go graphics processor with 64MB of DDR SDRAM. Kicking 3D graphics performance into overdrive with hardware transform and lighting (T&L) and an advanced ultra efficient memory architecture (Lightspeed Memory Architecture II), the NVIDIA GeForce4 delivers a dynamic, visually rich, real-time 3D graphics experience.
    I know you don't smoke weed. I know this. But I'm gonna git you high today. 'cause it's Friday, you ain't got no job, and you ain't got shit to do!
    Aug 2002
    No offers? No lowballers even! Guess no one is really a mac fan here. I'm looking at 4000 OBO.
    BUMP!
    I was going to offer $3000 this afternoon but I didn't want to lowball but since you asked for it I'll give you $3000!
    APR Audi S4
    Maybe 3400CDN? What do you think?
    Peter
    May 2003
    2007 Acura TSX
    That's a freaking NICE laptop... if I had the extra $$$ I'd go Mac all the way...
    Sep 2002
    BASTARD!
    Where did you steal that from ....
    I would be interested but I am BROKE
    Jul 2002
    FA1
    my laptop... if i had 4000 in my pocket i'd give it to you right away.. haha man.. i love macs
    APR Audi S4
    Hello???
    Evan... what's the word on this machine?
    Peter
  1. SEALED 128mb CF CARDS
    By hingkit in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-26-2003, 11:56 PM
  2. FS: 2 - JL 12w0 subs in a sealed box
    By BAMbunch in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 04-15-2003, 12:02 AM
  3. FS: BRAND NEW 15'' RS rims (WHITE) and NEW rubber. NEW PRICE $700obo
    By gokuu in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-20-2003, 01:05 PM
  4. New Apple products
    By Superesc in forum General
    Latest Threads: 01-08-2003, 02:47 PM
  5. MICROSOFT INTELLIMOUSE 3.0 :: Brand New - SEALED
    Latest Threads: 10-13-2002, 03:05 AM
