help: vibrating - Beyond.ca - Car Forums
Results 1 to 13 of 13
Thread: help: vibrating
    85 E30, 98 540I
    Default help: vibrating
    I started my 1998 E39 540i today in the morning and the engine began vibrating and the rpms were going down around 400rpm...while driving i felt a loss of power and it kinda bogged and shook at take off... any help with this issue would be great. i baught this car recently and there has been no tune-up that i know of done.
    Oct 2004
    M3 Boosted, M70 325is, M52 325is, 327sbc 328is
    So you bought a used 540i without inspecting it first......isn't this magical.....
    Mar 2007
    Rust bucketz
    Do some maintenance.
    Oil change/filter
    fuel/air filter
    plugs
    check tire pressure
    85 E30, 98 540I
    did i say i never inspected it? btw this problem just occured yesterday
    oil/filter were changed like 400 kms ago
    plugs/wires will be changed tommrow thnx sr240sx
    85 E30, 98 540I
    i scanned it at AutoValue and turns out it was a misfire in cyl #2
    i changed the sparkplugs and no change, the car is still vibrating and the next step is the coil packs..there are no sparkplug wires so ill see what goes on
    Jun 2004
    Calgar3h
    S14|TB1
    fill up gas lately?, maybe some bad gas?, we had a car at work with misfire, the lady said she filled up at some small town up north, turned out to be shitty gas
    85 E30, 98 540I
    yeah i guessed that too so will see i just droped 25 liters of 91 octane in it from empty and 2 bottles of injector cleaner so ill see if that helps but thankyou
    Aug 2003
    YQL
    Subaru GR
    check the coil boots before you replace the coilpacks. On my e36 I had similar issues, boots were cracked in 3/6....gl
    Psalm 144(1): Blessed be the Lord my strength which teacheth my hands to war, and my fingers to fight.
    85 E30, 98 540I
    one of them was cracked i dont think it was cyl #2....would that cause a misfire also?
    Oct 2007
    If the boots are cracked then yes it will cause a misfire but since it's in cylinder #2....
    When you see a misfire happening it could only be one of two things or a bigger problem. Usually it's the sparkplugs or cracked boots. Goodluck!
    85 E30, 98 540I
    I will be changing the boot in 1 hour and the spark plugs were changed...im hoping its nothing more than that
    85 E30, 98 540I
    problem solved it was the ignition coils
    Aug 2007
    98 & 03 Honda Accord V6
    Originally posted by SR240SX
    check tire pressure
  1. Vibrating Steering Wheel Help
    By ryeguy252 in forum Mechanical
    Latest Threads: 12-13-2007, 02:22 PM
  2. Help-Engine vibrating at stop
    By Deeohgee81 in forum Mechanical
    Latest Threads: 08-05-2005, 07:39 AM
  3. My b16 is vibrating!
    By ChadL in forum Mechanical
    Latest Threads: 02-24-2004, 08:51 AM
  4. Attn Civic owners: Vibrating mirror(s)
    By Ferio_vti in forum In Car Entertainment / Electronics
    Latest Threads: 08-03-2003, 08:09 AM
  5. rear-view mirror vibrating
    By szw in forum In Car Entertainment / Electronics
    Latest Threads: 07-01-2003, 03:28 AM
