How to do a battary relocation - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: How to do a battary relocation
    Sep 2007
    12 camaro ss ,91 aristo , 12 ram
    Default How to do a battary relocation
    Hey, Ok so i want to do a battary relocation to the trunk of my 1992 nissan silvia, What do i need to do this and what is the process. Is it easy to do or should it be done professionally?
    Thanks for any input!
    Jun 2006
    http://www.rpmoutlet.com/musv6batt.htm
    It shows the parts in there. Your just moving the battery to a new location (secured and boxed safely) and running your cables back to it (using sufficient gauge cable of couse). I do not know if you need to run a cable to the engine bay for the ground, since you just your your metal chassis as ground, but I do believe some people do for performance sake?
    Sep 2007
    ^^ thankss , i neeed to do it because i have a really small battary in the frount, I want a bit bigger one and have no room for it in the hood. Any one know where i can get a relocation kit locally here in calgary , Let me know Thanks
    Dec 2006
    i didnt use a relocation kit
    but you can pick up a aluminum taylor battery box at mopac
    and for battery cable use 2 ot weling cable it flows better and is ALOT cheaper than "battery cable"
    2001 celica pro mod project, in progress
    87 fox hatch,[email protected] skating, stock 5.0 shortblock,91 co-op pump gas, 11 lbs boost
    Sep 2007
    ^^^^ check pm
  1. b&m oil cooler/filter relocation..need o-ring
    By ca18det240sx in forum General Car/Bike Talk
    Latest Threads: 06-24-2007, 09:47 AM
  2. FS Aluminum Battery Box (relocation) NHRA legal
    By Primer_Drift in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 06-22-2005, 10:48 AM
  3. RCMP battery relocation
    By calgarys13 in forum Mechanical
    Latest Threads: 11-18-2004, 02:28 PM
  4. Replies: 5
    Latest Threads: 11-03-2004, 02:46 PM
  5. Battery relocation
    By buh_buh in forum General Car/Bike Talk
    Latest Threads: 11-05-2002, 06:38 PM
