Hey everyone, I'm trying to hook up strobe lights to my car and i want the strobe lights to come on with my alarm when it's going off and i would also like to be able to switch them on manually for shows. The unit its self would always be ON so that it would light up the strobes when my alarm is going off. So to do this i understand i need relays. I have used two relays in my diagram to control the siren and the switch. "X" is the power sent to my strobes when the switch is bridged, as well as when the siren is going off. "V" is where i plan to hook up the power wires from the siren and the switch. The switch and siren would not be simultaneously used as there really would not be a reason to but would there be any detrimental effects by doing so? Last but not least here's the diagram i did up on paint, please let me know if there is anything wrong with it or if there is something else i could do to make it a better setup. Basically both relays are connected to the power source for my strobe lights, other then that everything is separate.
Thanks for you help!
CAN THIS BE DONE?
