The file system and the file contents aren't really related. If you copy a file from 1 file system to the other it just affects how the file is stored on disk... so
1. Yes, you won't be able to edit it directly but you can copy it to the mac and edit it there.
2. again should be no issue unless you run into 1 of your files that's >4G
I think your idea of splitting it into 2 partitions is a good idea.
Try NTFS for Mac:
NTFS for MacŪ OS X allows you to:
Natively read and write your data to any Windows NTFS partition.
Easily transfer data between Windows and MacŪ computers using external or thumb drives with NTFS partitions.
Access NTFS partitions without having any complex translation applications or file services like AFP or Samba protocols.
http://www.paragon-software.com/home/ntfs-mac/
