Does anyone know of a shop that will do this, as well as how much it will cost?
Thanks!
Thanks!
Originally posted by InRich
tell her I'll pick her up in the vetteOriginally posted by InRich
A great place to get them serviced is canadian tire and its about 15 bucks each. Im glad you fixed the problem on the corado.
Couldn't have done it without youOriginally posted by born2workoncars
Xpress Lube Depending if you are in the NE or not, Costs about $70.00 for the fuel system clean I believe.
Other than that Canadian Tire Is Great.
Fuel system clean meaning what? I bring my car in and they throw some additive in the gas?Originally posted by phrozen
HAHAHAHAHAHAHAOriginally posted by phrozen
What was actually wrong with the Corrado?
just spray intake cleaner....
I have some injector issues, and found a great little shop to buy from in Michigan.
They may have what you need
injectors4u.com
rebuilt injectors, no core, $25/
OOOOoooo....
why dont u just buy some BG44K which i am looking for now.
RCTS does injector cleaning...
minit lube has a full fuel system cleaning system aswell, $100 bucks
it's better to pull them and get them cleaned and leak/flow tested.
injectors could be cracked/leaky, and no amount of cleaning will fix that.
But if your car runs fine then the IV drip throttle body/ injector cleaning from a lube place may improve performance.
I used seafoam and some concentrated injector cleaner, but it didn't help fix the leaky injectors , that's why I got re-built ones.
OOOOoooo....
Got em done at GCL Calgary...
Hey does anyone in Calgary ultrasonically clean fuel injectors??
It seems that when we pulled the injectors, as to my suspicions, one was black and oily.. The car still ran 155PSI all around on a compression test so i think the internals are okay... maybe something made it past the fuel filter???Originally posted by bennyhanna
We'll find out what the problem actually was pretty quick here!
-The Don
If you mean flow tested and matched, I sent mine out to this place:
http://www.cruzinperformance.com/fuelinj.html
They did an awesome job, and I KNOW they are all equal because they give you the results of the injectors after they test them. RCTS also does this too I think but when I last checked Cruzin is cheaper.
I did this because I was putting in used injectors from an E36 M3 and I was unsure of their previous condition.
Hope it helps.
Done and done... all 6 serviced including new rings and internals.. $180! well see how the car runs now!
