Lowered s13 wiring issue - Beyond.ca - Car Forums
Results 1 to 20 of 33
Thread: Lowered s13 wiring issue
    a fun 4 cylinder
    Default Lowered s13 wiring issue
    when a s13 is lowered on the drivers side the tire will rub through the fender liner and into the wiring harness and when going over a bump can cause the cars power to blip.
    my question is what have some of you guys done to remedy this problem?
    Nov 2007
    SR20 240sx / 2002 Jeep
    re-locate your wireing harness...
    a fun 4 cylinder
    how would I go about doing that?
    Hills of tuscany
    It's held together by zip ties
    zilvia is your friend
    btw, please tell me your not rubbing with stock wheels
    Nov 2007
    yepp, do a search on zilvia. you re-locate through your engine bay im pretty sure. i haven't done it yet but ive gotta do it for my new wheels this season.
    a fun 4 cylinder
    yes I am running stock wheels at the moment.
    Apr 2006
    Calgary/AB
    240SX
    my wires just corroded for no reason and melted together the the front wheel well. just strap them up higher?or like a skid plate
    a fun 4 cylinder
    myn didnt corrode its the tire rubbing against it
    Nov 2007
    lol how low is your damn car. how are stock steelies rubbing?
    a fun 4 cylinder
    i only lowered about 1.5 inchs at most. it could be front the stock profile on the tire. but I cant buy tires at this point in time. they are alloys but that shouldnt make a diffrence
    Jun 2004
    Calgar3h
    S14|TB1
    theres a harness in the l/f fender, you take the fender off and reposition the wiring bundle(yours is probably loose?), i would think that your tire would get shredded before the wiring harness starts screwing up, i believe there is a protruding weld right there
    this is all with removed fenderliners..
    like you said you have no budget for rims or new tires.. 50 or 45 sidewalls would be ideal, but then again why would you want to waste money on 15" low profile tires on an s13, i would save up and purchase 17s or 18s.
    a fun 4 cylinder
    exactly I want to throw some 17s on the front and 18 in the rear. I have herd that you can cover the harness with a peice of metal to sheild it from the tire. has anyone done this?
    yeah going to a 50 seiries tire on 15s isnt all that cheap your looking around $600-700
    Hills of tuscany
    just take the fender off and zip tie it higher up where it won't make contact. but ER sells a little metal cover for like $50
    and 17's/18's looks like shit. the fronts look way to small imo
    a fun 4 cylinder
    I found out the damage. 8 wires that completely sepearated from the car. once I sauder them back to one peice I will definetly put a metal cover over the wires
    Hills of tuscany
    ian on DW just posted these. probably the best pictures that show the quick fix i have seen yet
    Sep 2006
    There's also this thread on v240 http://www.projectzig.com/v240/index.php?topic=460.0
    I still think tucking the harness is a better idea than that plate.. Noble yamada on v240 actually rerouted his right through the engine bay. craaaazy.
    dv/dt
    a fun 4 cylinder
    now I just need to find the time to take off the fenders and do it
    Apr 2003
    '92 RPS13
    haha on my old car the tires burned right through the fender liner, but the suspension was stiff enough so that it wouldnt go through the wiring . I was running stock tires as well on like a 2.5-3" drop? I know what you mean tho, once it goes through the fender liner, the only thing left is the wiring harness
    But what Laurier just posted seems like a flawless fix, that way you wont have to worry about your wiring anymore.
    a fun 4 cylinder
    yeah I ended up taking off the fender and routing it above the pinch weld. and it seems to be soliving the problem.
    I got my daytimes, cruise and headlight retraction back.
    Apr 2003
    '92 RPS13
    Are you on coils or just springs?
  1. s13 wiring
    By laser05 in forum Mechanical
    Latest Threads: 05-01-2008, 04:32 PM
  2. FS - S13 BRIDE Bucket Racing Seat+ Harness for S13/R32
    By typhoonslippery in forum Automotive Parts [Aero/Styling/Interior]
    Latest Threads: 08-30-2005, 07:36 PM
  3. WTB:S13 240SX Dimmer Switch...any salvage s13's?
    By bw54867 in forum Automotive Parts
    Latest Threads: 04-22-2005, 06:48 PM
  4. Need Some Wiring Help Please....*Wiring GURUs Enter Here!*
    By Weapon_R in forum In Car Entertainment / Electronics
    Latest Threads: 04-21-2005, 06:38 PM
  5. Wiring Issue
    By slaya15 in forum In Car Entertainment / Electronics
    Latest Threads: 04-24-2004, 09:50 PM
