K so I'm low on clutch fluid and it says it takes dot3. The only thing I could find at the wal mart shelves where dot3 brake fluid...is this the same thing?
Should I only be getting dot3 clutch fluid???
i'm pretty noob at that stuff too but I think when it says Brake it should be used for brakes and when it says clutch it should be used for clutch
try canadian tire
same stuff yo.
i got a bottle you can have for free.
yes, it's brake fluid.
dv/dt
Yeah most clutches (if not all I'm not sure) use brake fluid.
yeah it would work
