Vacuum Leak / Smoke machine - Beyond.ca - Car Forums
Results 1 to 11 of 11
Thread: Vacuum Leak / Smoke machine
    Nov 2005
    F32
    Default Vacuum Leak / Smoke machine
    Been having a nightmare of a time finding where my vacuum leak is. I know that Sheni has a smoke machine but he is booked pretty solid right now. Also called BMW Calgary/Gallery and they aren't booking till June 12.
    Anyone know another shop with one? Or a good way of finding a leak??
    Thanks
    Calgarian Living in Edmonton
    Spray propane into engine bay, if RPMS go up, you found your leak
    Originally posted by GTS Jeff
    02 RSX
    silver hill acura has one
    Nov 2004
    Cgy
    ACS 328is
    spray carberator cleaner wherever ur leak may be (sp?) and the rpm will dip.
    spray it around your intake manifold gasket.
    it might be your intake elbow area.
    check for any cracks inbteween the rubber elbow and all gaskets in the intake system. you can generally hear a "HISSSS" sound.
    theres a couple hoses underneath your intake manifold as well. might want to check those.
    www.projecttechnik.com
    Nov 2005
    F32
    First, thanks for the replies. Much appreciated.
    So out of the two, which one should I used?
    Oct 2004
    2000 BMW 540i/6-spd & 2008 Triumph Street Triple
    My money is on the intake elbow... If you haven't replaced it in the last 5 years, that's probably it --you need to take it off to inspect it. $39 from Calgary BMW.
    Nov 2005
    F32
    would the intake elbow cause me to loose pressure under boost? I'm running 4psi (with poor idle) and i should be running 8psi
    Jun 2006
    i have a smoke machine. but its in red deer.
    Nov 2005
    F32
    i appreciate the offer. red deer is a little far though
    Oct 2004
    Well, you didn't mention it's running a turbo, but if the stock intake elbow is still being used with the turbo kit, I'd definitely take it off and inspect it, since it would be under alot more pressure that normal.
    Nov 2005
    F32
    just to make sure i have the right part, you are talking about this one right? (see image) I looked on realoem.com but I can't seem to find what the part # is for that.
  1. Unkown vacuum leak in RX7
    By ProjectR in forum Mechanical
    Latest Threads: 04-18-2006, 02:40 PM
  2. only gettin 4 psi??? boost leak? vac leak?
    By |SpEncaA| in forum Forced Induction Talk
    Latest Threads: 04-03-2006, 01:45 PM
  3. Vacuum leak / Boost leak
    By Zenshi in forum Calgary MR2 Owners Club
    Latest Threads: 09-25-2005, 10:03 PM
  4. Vacuum leak?
    By aiy_yah in forum Mechanical
    Latest Threads: 03-29-2004, 11:04 PM
  5. Vacuum Leak
    By joe626 in forum Mechanical
    Latest Threads: 08-26-2003, 01:43 PM
