My bad experience with JDM Tuners - Beyond.ca - Car Forums
Page 1 of 4 1 2 ... LastLast
Results 1 to 20 of 76
Thread: My bad experience with JDM Tuners
    Apr 2007
    Default My bad experience with JDM Tuners
    Hey guys I thought I'd just post a little about my horrible experience with JDM Tuners.
    My girlfriend cracked the transmission in her 98 Civic Dx. She needed a quick repair so she could get it running and get to work, otherwise I would have done it and there never would of been any problems.
    So I called JDM Tuners it was done within 3 days. (After having the price bumped from $500 to $1000 because they said that the JDM tranny would not fit and that I needed a USD.) Apparently the family tree of the car (EK tree) does not allow the JDM tranny to be installed.
    A little over a week after having the tranny changed the R/H wheel bearing goes and the car becomes very rough to drive. So I call JDM Tuners and the guy will not even let me talk to the mechanic. I accused them of using an impact gun on the lug nuts therefore compromising the bearing. Buddie agrees that yes they did in fact use an impact but they did nothing wrong that would effect the bearing.
    So I figured well the lug nuts have obviously been torqued on way to tight and this has compromised the wheel bearing.
    When I took the R/H wheel off and sure enough the lug nuts were so tight that I had to use a breaker bar to get them off. What I found next was the worst part.
    The axle nut was so loose that I could spin it off with my bear fingers. (The picture attached shows exactly what I saw when I removed the wheel. You can see how the nut is only threaded on 2 turns and all the scoring on the rotor from being so loose.) You could tell that there was no attempt made to tighten the nut. Even the pressed portion of the nut had not been pressed into the locking groove. There were no fresh tool marks so this leads me to believe that it was never tightened properly to begin with.
    Clearly I was right that yes they had in fact somehow compromised the bearing one way or the other.
    So I called back after it was all said and done and told the guy that I am going to need some sort of compromise. I told him that the bearing was $70 and it took me 3 hours to change it so all in all I needed a $100 refund and I wont tell anyone about my shitty experience with their shop.
    Well the guy protested that they never did anything wrong and basically hung up on me and is screening his calls now.
    Just thought I'd let everyone know that this place does some pretty shady work and for all the buyers out there to be aware.
    sketchy
    Mar 2005
    Cgy/Edm
    Jetta
    to disreputable business & not living up to your mistakes.
    Apr 2003
    00 Honda CR-V, 02 IS300
    thats garbage... so they used an impact on the lugnuts, but not on the axle nut???
    oh, and if the tranny was from a D-series EK motor from japan, then it'll fit on a d series here... if they were trying to fit a B series tranny on a D-series motor, then they are smoking some good shiet...
    Nov 2003
    Accord 6-6, Tacoma
    I'd report that to the better business bureau, they keep records of stuff like that. In time, it will catch up with them
    Honda/Acura guy
    Jun 2004
    Calgar3h
    S14|TB1
    Default Re: My bad experience with JDM Direct
    well alot of dealerships and tire places put lugs back on with impact guns.. but i guess the key word would be impact gun w/ a 80ft/lb torque stick or torque wrench set at 80 ft/lbs
    where is this JDM Direct, never even heard of it? in Calgary?
    and not tightening an axle nut is like they might as well have just put one cv shaft in and thats it, i expect the over torquing of lug nuts be done by a customer more often than the mechanic any day.
    Apr 2007
    Ya the SE just behind cash casino on blackfoot.
    Left was ok looked like they had not even touched it.
    Yes I hear you a lot of places use impact guns and usually I do to.
    But how the hell do you miss the axle nut thats a pretty major component.
    Atleast own up to your mistakes instead a get the big fu!
    Mar 2008
    Calgary,Alberta
    Da1.8t , e46 m3 , dc2 Gsr supercharged, 2001 typeR
    tightning lug nuts with an impact gun has nothing to do with the wheel bearing getting fuked up , and also the wheel bearing fuking up was not their fault it was probably just worn out , wheelbearings are one of those thing u really cant break or fuk up its just wear and tear on a vheicle , and u are lucky to get the tranny done even for taht price 1000 is nothing most places charge just for the tranny over 500
    Mar 2008
    Calgary,Alberta
    but lug nuts are usually tightened with the impact then torqued down , and dono what to say about your axle not but the rest of the stuff is not their fault
    May 2007
    Winnipeg/Saint John
    18 Model S, 20 Macan S, 67 Camaro & 11 SLS
    wtf? havin' few sunday night drinks?
    Apr 2007
    Haha ya a few to many on a sunday night
    doooode
    I don't think it is a Coincidence that the axle nut was loose and the bearing went.
    Apr 2007
    bah one more thing sorry guys
    the shop is called
    JDM TUNERS
    Nov 2004
    In Transit
    2015 MK7 GTI
    Did you try to remove the axle and see if the protective cover is still in place over the wheel bearing?
    If you have a loose axle and that cover is gone, wheel bearings could go bad really really fast...
    Home of the Flames beaotch
    the bandwagon!
    aren't they a beyond sponsor?
    Apr 2007
    Please describe the location further....
    Are we talking from the axle to the back of the bearing...
    If so there is no cover there.... is the cover mounted with the bearing into the steering knuckle???
    I bought a new sterring knuckle from a fellow beyonder since I broke the original trying to press the bearing out. There was no dust cover with the 3nd hand knuckle....
    Apr 2007
    I wouldnt be suprised if they were a sponsor.... many people do get work done there off beyond thats why I am suprised that they are being so ignorant.
    Nov 2004
    In Transit
    2015 MK7 GTI
    Yeah it's on the back of the knuckle where you see the bearing. It's basically a round metal ring that goes between the knuckle and the axle and it protects the bearing. It is actually pretty easy to pop off and remove and is usually only lightly tapped on.
    Mar 2007
    Default Re: Re: My bad experience with JDM Direct
    Well, this is true...a torque wrench is much better than just the torque stick....cause I have seen a many lug nuts still very loose after it was put on with an impact w/ a torque stick.
    The best way to do it is, in my opinion, with a impact gun, than torqued with the torque wrench afterwards...
    Aug 2003
    YQL
    Subaru GR
    http://forums.beyond.ca/member.php?s...o&userid=40511
    maybe....
    Psalm 144(1): Blessed be the Lord my strength which teacheth my hands to war, and my fingers to fight.
    Apr 2007
    hmmm ok so just to correctly understand you it is a ring placed in the knuckle before the bearing is pressed in?
  1. JDM Tuners
    By rollinv4l in forum General Car/Bike Talk
    Latest Threads: 12-23-2007, 08:04 PM
  2. experience w/ JDM Tuners?
    By red99600 in forum General Car/Bike Talk
    Latest Threads: 12-09-2007, 07:42 PM
  3. A horrible experience; turned great experience
    By Graham_A_M in forum Bike Talk
    Latest Threads: 04-09-2007, 05:56 PM
  4. Jdm Tuners Inc.??
    By hoppy2018 in forum General Car/Bike Talk
    Latest Threads: 03-07-2007, 02:37 AM
