looking for an installer to install speakers front and back.
got quotes ranging from 750 - 400. Pm me for more info..thanks..
pm wrxer1
wrxer no longer installs, hes out of the business, as are most of the backyar installers these days... lol to much liability
what vehicle?
oh, i didn't know that, thx for the update
2000 honda civic coupe
holy crap, that sounds alot for just replacing speakers, are you doing any special work like installing new components in the front, running an amp or anything like that? or is it just replacing the speakers?
components in front, need to run all the wiring to a 4 channel amp in the trunk.
Is that including the speakers?
I am Ihatetowait and this is what I say ^
no. thats just labour...
that really seems like a lot to install speakers and run lines, so that's just for labour only, no materials at all?
wow!!! so much $$...especially in a civic its a piece of cake.
Best buy of FS will do it for:
$60-80 4 chan amp
$100ish for Components assuming they will have to cut your panel for the tweeters and build a wood spacer for mounting depth.
$40 Rear
Not saying that i reccommend them, just letting your know who ever quoted you that much is off his/her rocker!
obviously never done rear speakers in a civic coupe
Sure have!
Used to be an installer!
Pretty useless installer then if its a "piece of cake"
i can get it done in under 40 minutes but it is tough. the entire rear end has to come off including seats, rear quarter panels, and rear deck.
front speakers are fairly easy but you need an air saw to cut the plastic out behind the factory speaker because its so shallow.
other then that everything is pretty straight forward as long as you have all the wiring (60ft of speaker wire, and 2 sets of rcas, and obviously power/ground/remote)
Need this done this weekend.. i have all wiring and cables..
you can come see me at beacon hill future shop to get it done up to you ?
i ended up doing it
thanks again takemtochurch....
