Dry wall taping - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Dry wall taping
    WRX STI
    Default Dry wall taping
    Any one here do dry wall taping? I have a garage that is dry walled but not taped. I want to paint it this year. Please let me know or pm me if you do. thanks.
    Eclipse
    Default Re: Dry wall taping
    it really isn't all that hard, buy a do it yourself book, and you can save a lot of money...
    Not worth paying someone 2 drywall a garage for you...
    Originally posted by beemerm3
    so if we only seen 5 % of the oceans why not drain them or somethin lol or can u even transfer water from one ocean to another??? think of all the stuff u'd find treasures n eerything.
    Dec 2007
    http://www.doityourself.com/stry/installdrywall
    Hope it helps.
    Taping is step 10 im pretty sure.
    May 2003
    Taping is easy. It's the god damn sanding that sucks ass.
    But in the Garage, I'd say it doesn't matter nearly as much, so I would do it yourself.
    Nov 2003
    If your good at taping/mudding your sanding is really really easy.
    buy quality drywal mud,.. not the cheap all purpose no-name stuff in white buckets
    westrock - easy sanding
    synko - easy application
    these come premixed,.. but use a 1/2" drill and a whip and "fluff" them up with a few to 6 cups or more of water till there is a consitence you like.
    fyi: the more water you use,.. the more it will shrink back
    sand between coats
    3 coats
    first coat - 8" - feather the edges
    sand
    second coat - 12" - feather edges
    sand
    third coat (make it the mudd more thinner/soupy) - overlap 12" on top and bottom to make an approx 18" skim coat - put on/take off - just to fill all the imperfections
    finish sand with 150-180 grit paper-back sand paper on a sanding pole or hand sander,.. never use the "mesh" sand paper - never use an electric sander, best results are done by hand.
    wear a mask - the dust will make your beathing shallow
    if you are skilled enough you can do a 4th skim with a well sharpened/used 12" trowel dipped in hot water to give you a virtually sandless taping job
    rookies - use knives and a metal mud pan, i suggest a 6-8" for laying the tape, 8-10" for first coat, 12" for 2nd and 3rd coat
    skilled people - learn to use a trowel,.. this will give you the skills to do stucco, concrete finishing, ceiling textures.
    12" trowel + a good magnesium hawk, 6" knife for laying tape, 4" for inside corners
    Tip for all:
    inside corners - put mud on both sides - lay tape - flaten and wipe - coat only 1 side nice and as smooth as you can in the least amount of strokes - feather edge - wait till its fully dry (1-2days) then coat the other side
    Outside corners:
    rookies - use plastic corner beads and spray adhesive, either 3M 888 (or something like that) or Trimtex 847 - spray corner, spray bead, wait 10 secs, apply, coast 3 times over 3 days
    skilled - use paper covered metal bead, put mud on both sides with 6" knife, apply bead, wipe flat paper and remove excess mud, then make your fist coat rght away with 12" trowel only about 8" wide tho, wait till dries (1-2 days) sand and coat again, but go 10-12" wide, next day, sand and skim coat
    round bead you need to do 4 coats
    There you have a run down on how to do drywall taping
    Back to the origional post for a garage,.. go back to the top of my post and only work to step 2,.. it's just a garage
    I used to professionally tape houses for years - no I won't do taping anymore,.. i hung up my tools, I sell houses now.
    I think I posted everything anyone needs to know, pm me f you have any q's
    Jun 2004
    2018 Lexus IS350 AWD F-Sport 3
    my buddy allan is an insane taper and really decent guy
    probably get you a good deal
    pm me if u want his number....where abouts do u live?
    These opinions are entirely my own and do not represent any other person or organization.
  1. FS: Drywall Taping and Mudding
    By clockworkboy3 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-31-2007, 01:27 AM
  2. Fs: Wall Mount And Wall Cube For Plasma/lcd
    By toomuchb00st in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-12-2007, 03:40 PM
  3. Drywall Taping/Mudding
    By BrknFngrs in forum General
    Latest Threads: 05-16-2007, 08:51 AM
  4. Rain dried up -- South is dry -- Here we come Race City!!
    By Fluidic in forum Events and Meets
    Latest Threads: 04-26-2003, 03:57 PM
  5. Wax as you dry...ne good?
    By 2K255HP in forum Performance Modifications
    Latest Threads: 09-09-2002, 05:55 PM
