Hey guys! I have a friend that is in need of some help. He jus bought the teg wit 184 xxxkms, and we're running into some minor problems.
1. sometimes on start up, the idle is irratic, bouncin like its kind of retarded ( from 2500 then drops etc. )for a little while then goes
calm after its warmed up a bit.
2. when the car is warm, the temperature gauge is on the proper area of the gauge ( just under half ). this is at idle. When the car starts driving the temperature starts to go straight down to where as if the car was just turned on ( on the cold side )
3. The car isn't getting much mileage, close to 400 kms to a tank. Car doens't burn or leak anything, plugs look good, engine bay is very clean, air filter was horrid, already changed.
What could these problems be and.. for the MPG, what can we replace to get some better mileage ( this is normal driving, barely driven hard )
Thanks in advance!!
