Turbo-Manifold Gasket - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Turbo-Manifold Gasket
    Feb 2003
    A Hobo
    Default Turbo-Manifold Gasket
    Hey there,
    I've been fighting for a while with sealing the turbo to the manifold .
    I started with the high temp copper . of course that's only good to 700F and the vibration wears it away .
    Then i went to one of those CarbonX sheets . It was nice for nearly 24 hours . Then the vibration got to it .
    What next? I was thinking of cutting one from a copper plate . But i'd have to find a copper plate first .
    Or does anyone have any suggestions to what to use? Or a place in town that might carry a gasket for a GT25R ?
    Jun 2005
    '05 Subaru LGT wagon (5MT)
    atpturbo.com and order online.
    I use a steel gasket with a rolled edge and haven't had any issues with inlet gaskets, discharge gaskets are another story though.
    Oct 2004
    AB/NS
    Have you made sure the surface is flat?
    Feb 2003
    A Hobo
    hi there. yeah the surface is very flat . I put the two together 2 days ago when i replaced the gasket with one of htose carbonx ones .
    i just phoned alamo . i forget they existed until i was on hold with speedtech and i remembered my friend getting a turbo rebuild kit from there .
    they have plenty of gaskets, i'm heading there now
    http://www.alamoturbochargers.com
    Dec 2007
    Airdrie Alberta
    are you sure your nuts arent backing off? thats very strange that your gaskets would go simply because of vibrations, ESPECIALLY with a copper gasket
    Feb 2003
    A Hobo
    i might not have made myself clear . i don't have a copper gasket, the question was where to get one .
    the nuts are backing off . bolts are backing off due to vibration . then the more vibration causes the gasket to wear .
    Jul 2002
    I've always used studs with hi temp loctite in the manifold. it makes it easier to take off/put on the turbo too. Once the turbo is on there, I use a lock washer and a nut with a dab of some more loctite. Has always worked.
    Also I use the same gasket mentioned...from atp turbo.
    Built not Bought.
    Feb 2005
    Saskatchewan
    There is no need for a gasket if both surfaces are flat. I had the same problem last year, kept blowing out gaskets and had a bad case of turbo lag. Just take the manifold off and take the turbo and manifold to a machine shop to get it resurfaced. Problems solved. Use lock-tite on the four bolts holding the turbo and manifold together. I also used lock washers.
    93 Civic Hatch
    12.0 @ 116mph (10psi)
    a.k.a "50 footer"
    Nov 2004
    In Transit
    2015 MK7 GTI
    ^ same for me and it never leaked.
    Apr 2005
    if both surfaces are flat (check them with a straight edge)
    I have used a thin coat of muffler cement and it held great
    as well as a thin coat of grease, then when it heats up it will seal it very well as well. but the surfaces have to be flat
    Oct 2004
    AB/NS
    Depending on the size of the flange it can be as simple as running a belt sander over it.
    Dec 2007
    Airdrie Alberta
    Theres a special anti-vibration washer that me and my friend are trying out, basically if you take the washers, put them on a nut/bolt, and just put them hand tight, you cant undo them unless you have a wrench and use about 15 ft/lb of force. I can ask him where he got them for you. Even if you get a copper gasket, if the bolts back off its still going to mess it up.
  1. fs: honda d-series HF manifold (almost a factory turbo manifold) and turbo
    By marc in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 04-30-2008, 09:17 AM
  2. FS: B18a head gasket + intake gasket
    By illeagle in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 01-06-2006, 01:25 AM
  3. FS: D15/D16 Civic Turbo Manifold (Hf/CX Manifold)
    By egmike in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 05-12-2005, 12:53 AM
  4. b16a intake manifold gasket
    By jfulton in forum Mechanical
    Latest Threads: 05-23-2004, 07:16 PM
  5. h22a exhaust manifold gasket.
    By LUDELVR in forum Mechanical
    Latest Threads: 03-10-2004, 09:29 PM
