Engine and exhaust
ACT - Heavy duty pressure plate
ACT - 6 puck unsprung ceramic clutch disc
Custom - Tubular Exhaust manifold
Custom - Ported Waste gate
Custom - Street port
Custom - Throttle Body modification
Earls - AN-4 Turbo oil supply line
Eunos – 90amp alternator
DSM - Blow off valve
FD - Oil Pressure regulators
Flexlite - 2300CFM 17" Electric fan
K&N - 4" cone filter
Racing Beat - Complete 3" Exhaust
Racing Beat - 3mm Apex seals
Racing Beat - Aluminum Flywheel
Racing Beat - Oil pressure slug
Racing Beat - Oil cooler lines
Rx7 specialties – serpentine belt pulleys
S5 - JDM Transmission
S5 - Turbo
Speed Machine - 18x9x2 V-mount intercooler
Turbonetics – 60-1 trim
Fuel System and Engine Management
Aeromotive - 6001R Fuel pressure regulator
Bosch - 680cc primary injectors
Earls - AN-6 Fuel fittings and hose
Haltech - E6X
Haltech – boost control solenoid
LS1 – Ignition coils
Magnacore – 8.5mm helicoil plug wires
Marren - Fuel pulsation dampener
NGK - Platinum spark plugs
RC - 1000cc secondary injectors
Walburo - 255 Fuel pump
Suspension, Wheels, Tires and Brakes
10AE - TII rims painted Mazda black
AWR - Rear control arm camber adjusters
Bridgestone - Potenza G009 205/55R16 H
Custom – Depowered steering rack
Custom - Front upper strut tower brace
Custom - Front Lower strut tower brace
Dunlop - Super sport 205/55ZR16 Y
Hawks - HP+ Rear brake pads
Hawks – Black front brake pads
Nissan skyline – GTS rims 16x6.5 5x114
Powerslot - slotted brake discs
BC Racing - 8k/6k Coilovers
Racing Beat - Adjustable sway bar links
Racing Beat - Pro-comp Rear differential mount
Racing Beat - Rear Steer eliminators
Racing Beat - Rear Sub frame Adjuster
Speed Machine - SS brake lines
Yokohama – Advan H compound race tires
Interior, Exterior and Electronics
Custom – 4pt roll cage
Custom - Relocated battery to pass. cargo bin
Optima - 720cca battery
RCI – 5 point Harnesses
Taylor - master battery cut off switch
Miscellaneous
5one5 innovations - Limited 3 gauge pod
AEM – Wideband Air/fuel gauge
Autometer - Boost gauge
Autometer - Oil Pressure Gauge
Flagfire – 5lbs fire extinguisher
Rotary Concepts - Oil Filler Cap
2011 Chevy Colorado Z71 - 5.3L LH9 - Daily driver
2003 Mazda B4000 on 35s
