Anyone know of one?
Anyone know of one?
if you're jailbroken you can dl im+
That uses MSN? How- I DL'd it and couldn't figure it out. Mind you, I only used it for a few minutes.Originally posted by gpomp
i'm using palringo
+1Originally posted by gpomp
i'm using palringo
I'm using IM+ ... it doesn't require you to register like Palringo
How much is it?Originally posted by beecue
app store says it's free but there is comment that says it's $29 after 10 days .. I have only tested to see if it actually works
So I downloaded and installed Palmringo, and now none of my apps work. They all close a few seconds after I open them. Anyone have any idea what the hell?
Re-start your phone and see if they work.
No dice.Originally posted by shakalaka
I have the same problem too.Originally posted by A790
No dice.
i'm using palringo
the best part: FREE
FRING, if its compatible...
No dice.
That's weird. I had the same problem and kept on cliking different applications for them to open and my phone automatically restarted itself and they were working and this has happened a few times. Maybe try syncing it with itunes including the applications and see if they work after. If not then you might just have to take them and out and restore or phone and re-install the applications. Before all that might as well try a hard reset. Hold the bottom and top button together for few seconds.
beejive ftw
meebo is the best
