block heater - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: block heater
    Jun 2003
    03 SVTF
    Default block heater
    Hey there
    gotta install a block heater but can't seem to find where it goes. It's a ZC and it looks like it is supposed to go in beside headers... but that doesn't seem right.. isn't it supposed to go in higher.. like around the oil filter area?? ne1 know for sure cause i can't see it that well... lol blind as a bat!
    thanks
    Jul 2003
    chestermere
    89 Civic ZC
    I don't know where they go, I'll try to find out tho.
    Bunch of Honda's
    i looked into this last year when i got my zc put in and i was told it didnt have a block heater... so your shit out of luck
    Sep 2003
    state of boredom
    Vettes mostly, some Stangs and a turbo 4 cylinder
    Wink
    There should be a "frost plug" on the engine block - looks like a hole with a metal disk pushed into it. All engines have them - the frost plug is supposed to pop open when the coolant starts to freeze - "hopefully" preventing a cracked block. Traditional block heaters replace the frost plug - fitting into that hole in the engine block. You can also get an inline block heater that is installed in the heater hose. You must remember to the leave the the car heater in the "ON POSITION" when you are using that type of "block heater"..
    I never had to use a block heater when living in Northern Canada. With the advent of full synthetic "winter weight oils" (0W-50) and fuel injected, computer controlled engines, block heaters became redundant - except in POLAR weather conditions.
    Make sure you are running 50 / 50 water and antifreeze when operating your car in Canada. Antifreeze is cheaper than an new engine block.
    hope this helps somewhat..
    tt
    Jun 2003
    03 SVTF
    88crx... are you still running your ZC? any probs during the winter?
    oreo cookie
    a wrx.
    a lot of old jdm engines dont have provisions for a block heater. if your car normally starts up easily, u have oem engine management, and u do all the usual winterizing stuff...it shouldnt be a big deal.
    Bunch of Honda's
    i didnt have any problems last year... i had it in since the end of january
    Jun 2003
    03 SVTF
    k thanks!!
  1. Cracked block???
    By EG STyLeZ in forum Mechanical
    Latest Threads: 03-09-2003, 10:51 PM
  2. HUGE accident outside my block...
    By Davetronz in forum General
    Latest Threads: 01-14-2003, 03:14 PM
  3. Pop Up Block Programs!!
    By Importz in forum General
    Latest Threads: 12-02-2002, 12:08 AM
  4. Block Heater
    By szw in forum General Car/Bike Talk
    Latest Threads: 11-04-2002, 10:26 PM
  5. FS:LS Block W/Type R Internals
    By JDMAE86 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-06-2002, 08:58 PM
