Great shape, used for about 6months
$30
Here's the info on it, taken from the pages of
memoryexpress
- 80mm low noise cooling fan
- Dual 12V outputs: 12V2 for Motherboard and peripherals; 12V1 for processor
- Industrial-grade protection circuitry prevents damage resulting from short circuits, power overloads, over voltage, and under voltage
- 80 PLUSŪ certified
- 4 SATA connectors
- PCI-E connector: one for 380W and 430W, two for 500W
- Safety approvals: UL, CUL, FCC, T V, CE, CB, C-tick, CCC
- Universal input
- Active Power Factor Correction (PFC)
- PF value up to 99%
- AQ3 Antec Quality three-year parts and labor warranty
Specifications
Maximum Power: 430 Watts
Switches:
- ATX Logic on-off
- Additional power rocker switch
- 115/230 volt selector switch
Special Connectors:
- ATX12V
- 3-pin Fan Sensor
- SATA
Transient Response: +5V, +12V and 3.3V outputs return to within 5% in less than 1ms for 20% load change.
P. G. Signal: 100-500ms
Over Voltage Protection recycle AC to reset:
+5V trip point < +6.5V
+3.3V trip point < +4.1V
+12V trip point < +14.4V
INPUT
Input Voltage: 115VAC/230VAC
Input Frequency Range: 60Hz/50Hz
Input Surge Current: < 60A @ 115VAC/< 80A @ 230V
Input Current: 10.0A for 115VAC / 5.0A for 230VAC
Hold-up Time: > 17ms at Full Load
Efficiency: up to 85%
EMI/RFI: FCC Class B
OUTPUT
Voltage: Max. Load / Min. Load / Load Reg. / Ripple V(p-p)
+3.3V: 20A / 0.5A / 3% / 50mV
+5V: 20A / 0.3A / 3% / 50mV
+12V1: 17A / 1A / 3% / 120mV
+12V2: 16A / 1A / 3% / 120mV
+5V SB: 2.5A / 0A / 5% / 50mV
-12V: 0.8A / 0A / 5% / 120mV
* Total: +12V output: 30A
* +5V and +3.3V combined output: 32.8A
ENVIRONMENTAL
Operating Temp.: 0 to 50 C
Operating Alt.: Sea Level 10,000 ft.
Non-Operating Vibration:
- Operating: 10-300 Hz, 0.5G, 3 axes, 1 hr. ea. axis
- Non-operating: 10-300 Hz, 2.0G, 3 axes, 1 hr. ea. axis
MTBF: 80,000 hrs. @ 25 C
Approvals: UL, CUL, FCC Class B, CB, T V, C-Tick, CCC
DIMENSIONS
Unit Size:
- 5.9"(W) x 3.4"(H) x 6.1"(D)
- 14.9cm (W)x 8.5cm (H) x 15.8cm (D)
Weight: 5lbs.; 2.3kg
