NA cars and our 1/4 mile tracks - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 48
Thread: NA cars and our 1/4 mile tracks
    Mar 2008
    Lacombe AB
    Default NA cars and our 1/4 mile tracks
    http://www.albeedigital.com/supercou...0-60times.html
    Seems like na cars run 1 sec slower on our 1/4 tracks.what are owners of rsx s owners running 15.8-16.00
    I'm liking them now but seems like a lost cause to try to run 14.8 stock @ castrol
    Nov 2004
    In Transit
    2015 MK7 GTI
    yeah pretty much
    Aug 2004
    Beyond
    Various degrees of slow.
    For a stock car I feel your predictions are about right. Really did not see any running last season at RC.
    Was the #1 Forum Warrior
    Apr 2004
    1985 300ZX
    Compared to what other tests?? Other tracks??
    Just a shot in the dark here but what affect does the altitude have here on car racing? being we are 3500ft above sea level, I know I used to notice a difference in my car when I took it down to sea level.
    The air is way less dense up here and there for more air is required and I can see NA's noticing it more. that has to play a big factor in times
    Speedy
    1985 300ZX & 1991 300ZX
    Mar 2008
    Lacombe AB
    Mags,tv shows,also have 2 charts of 1/4 mile tests
    Aug 2003
    City:Calgary State:Omnipresent
    AE92GZE, Legacy BL, Yaris
    Default Re: NA cars and our 1/4 mile tracks
    Link above of 1 1/4 mile chart
    Well ... ya of course.
    Altitude has already been mentioned. Traction is also a factor, the Southern US tracks never see winter and are maintained better.
    Jul 2002
    Lesson from all this?
    Don't buy NA cars in Calgary
    Mar 2008
    Lacombe AB
    Are stock f/I cars running stock advertised times?
    Aug 2003
    F/I narrows the gap but they are closer but still slightly slower than advertised - especially at race city.
    Nov 2004
    In Transit
    2015 MK7 GTI
    they aslo run slower lol. The altitude and traction at our track are far from optimal.
    Castrol raceway is usually about 0.4 to 0.5 seconds faster and 2-3 mph more for the same setup.
    I have seen many SI's run 16.5 here but I think most of it is the driver and very few are good enough to extract everything the car has to give.
    I took 2 different cars out for one pass each last year, had never driven them before and beat the owner's personal bests so it's really more about driver than track an altitude.
    Whatever you have it can probably do better with a bit more practice!
    06 S2000
    Awe, go ahead and make me feel good about myself.
    +1 he beat my personal best in my own car by .2 seconds on his first and only attempt in it.
    Mar 2008
    Lacombe AB
    Mar 2006
    AB
    Stuff
    Okay, I'll try this.
    Sea level is 14.7psi, the higher altitude you go the less pressure there is in the atmosphere. The less pressure means the air is less dense which lowers power. You can figure out how much by doing the math. If our pressure here is 13 psi (I didn't actually look it up) then you are running 88.4% less air pressure (13 divided by 14.7) than you would at sea level. I don't know if that means that you are running 88.4% of your power but it is less power.
    With a forced induction vehicle you are changing the pressure of the air going into the engine, so if you are using 10psi boost you are putting 23psi into the engine if normal atmosphere at your elevation is 13psi. So that changes the percentage of power loss (23 divided by 14.7). 156% more air pressure than normal atmosphere.
    I'm sure the smart people are going to tear this apart, haha.
    I like cars.
    Not Aspen
    Two from Freemont
    With FI cars, it all depends on if they are MAF based or MAP based.
    MAP based cars will make the same power here as they do at sea level. MAF, not so much.
    Mar 2006
    AB
    Stuff
    Won't it always be less here at the same boost level as sea level?
    I like cars.
    Dec 2008
    calgary, ab
    CRV, MDX, CRX
    is the track prep at racecity really that bad?
    I just moved here from abbotsford and mission raceway is at 22 feet altitude i believe. I know altitude plays a huge factor in NA power but I don't know exactly how much. I am rusty at the track as i didn't race at all last year, but i am going to try out my car this summer at racecity and compare. I bet .3-.4 slower and 2-3 mph different.
    Any educated guesses?
    13.02 @ 102mph NA B16
    B18C is in and running!
    a van down by the river
    yes
    Mar 2008
    Lacombe AB
    Mar 2007
    LA
    charger R/T w R&T, soon 2010 camaro
    i have a charger r/t and people are hitting 14.5 stock down in the states and every pass i did in race city was 15.5-15.4 secs
    Aug 2004
    N/A V8, TTV6, DOHC N/A V6
    Depends on the driver.
    I hit 15.7 with my FG2, with a 2.43 (awful I know) 60ft. I could do 15.3ish with a 2.2
    Sorath ran a 15.2 with his Si though.
    -H.P. Lovecraft
  1. Texas Mile 2008 - Ford cars
    Latest Threads: 04-02-2008, 02:15 PM
  2. Nissan GT-R recognizes tracks via GPS and removes speed limiter
    Latest Threads: 12-23-2007, 03:04 PM
  3. website where u can pick and play tracks
    By jay42w8 in forum Entertainment
    Latest Threads: 01-29-2007, 06:56 PM
  4. HAWC tracks down hit and run suspects
    By sputnik in forum Society / Law / Current Events / Politics
    Latest Threads: 07-23-2004, 09:46 PM
  5. Looks Like Its Time To Put Our Cars Away Boys..Snow
    By TomTom in forum General Car/Bike Talk
    Latest Threads: 09-20-2002, 04:34 PM
