Dual Core or Core2Duo? - Beyond.ca - Car Forums
Results 1 to 20 of 24
Thread: Dual Core or Core2Duo?
    Dec 2007
    Default Dual Core or Core2Duo?
    What is the difference between Intel Dual Core and Core 2 Duo, and which one is would you recommend?
    Jul 2008
    "Core 2" an Intel brand, representing its flagship consumer line of processors based on the "Core 2" microarchitecture. Core2 processors are available in Solo, Duo, and Quad configurations, representing 1, 2 or 4 cores respectively.
    "Dual Core" is a term reserved for chips that contain more than one processor in a single chip. The term has no specific definition of requirements, with regards to what comprises a second core, whether independent cache is required or just a second processing thread.
    Core2Duo processors are "dual core" chips. However, it's important to note that all dual core chips are not Core2 chips. What you are probably referring to is another line of chips, the Pentium Dual-core line. The Pentium dual-core line is marketed as a cheaper and slightly inferior line of chips compared to the Core2 line. The microarchitecture of both chip lines are extremely similar, and have evolved in unison since their inception in 2006. The real difference is that the Pentium line is fitted with smaller L2 cache than the Core/Core2 models.
    We highly recommend Core2Duo or Quad processors. Real world performance differences over the Solo and Pentium processors is significant, especially in terms of responsiveness. The extra execution thread and cache really make a difference.
    Jun 2004
    Mitsubishi Lancer GTS 08
    ^^ what he said
    Mar 2007
    Regina
    Also be aware the Intel has just Pentium dual cores. Also there is core duo's which are the predecessor of the Core 2 Duos
    Dec 2007
    Which one would you guys recommend?
    ...searching
    Core2 Duo AS PER ABOVE.
    My MacBook Pro (first version, shipped April '06) has the Core Duo. The current MacBook Pros have Core 2 Duo (Late '07-present). Which do you think is better?
    Mar 2007
    Regina
    depends what you want your pc for. Core2Duo is more then enough for the average user but if you are a hard core gamer, video editor etc. you may consider stepping up to a quad core.
    Mar 2007
    Regina
    Core2 is hands down better then the Core Duo but is it enough to justify an upgrade? Probably not unless you need the extra speed.
    Jun 2007
    I wonder when theyre coming out with quad for laptops.
    Originally posted by Thaco
    get an lcd for anywhere, with the 120/240hz it's superior in all ways.
    LOL
    Mar 2007
    Regina
    There is already a couple out. Check out the Acer Aspire 8930G.
    Sep 2007
    2004 Ford Mustang
    ^^ agreed, although the Core2Duo may seem a little more expensive than some similar AMD processors, the performance you get out of the Core2Duo is much better. It's the old "You get what you pay for"
    A good example is I do alot of virtulization at home, and when I first built the PC that I am using I cheaped out and bought a AMD dual-core processor, When in retrospect, I should have just bit the bullet and spent the extra money on the Intel, much better performance. I have a Core2Duo E8400 w/ 4GB of RAM at work and the thing just screams!
    Jun 2007
    Oh, well but unless youre doing super heavy apps like graphic apps or gaming Core2duo is still more than good enough for laptops.
    I thought AMD CPUs were known to be faster and more bang for your buck? Maybe that was back then? and for games mainly?
    Mar 2007
    Regina
    They were years ago. But for the last bit, especially since the Core Duo came out I'd have to say Intel for the most part destroys AMD's. But as stated you do pay a little more for "the same specs".
    GLC43
    AMD hasn't been the gamer's choice for 2-3 years now. Ever since Core started. They are so far behind and now lack of cash, I doubt AMD will be competitive again.
    I still don't know if there are benefit to going quad core unless you are playing with virtualization. For the price, I rather get a faster dual core than a slower quad core.
    Apr 2006
    Cowtown
    10' 4Runner SR5
    For guys with laptops, I've heard the AMDs drain your battery a lot faster than the intels.
    Follow me on Instagram and Facebook!
    Feb 2006
    Mazda 3 GT
    Just to clariy: Core and Core 2 are the names of the line, not Core 2 Duo. The "Duo" or "Quad" part refers to the number of cores. And yes, Core 2 is much better than Core. And regarding AMD - agreed, they haven't been in the game since Core. And even now, with Intel's new Corei7, AMD is further behind than ever before.
    Stop with the antics. Beyonder.
    Sep 2006
    +1
    Dec 2003
    2011 Audi TTs
    that depends if it using "centrino" technology, centrino is an intel hardware package including the motherboard, cpu, wireless, and chipset, in many laptops to help optimize battery performance, which ultimately destroys AMD's when it comes to laptops....although the relative capacities of batteries also plays a role in how long a laptop will take to run out of juice when you're on the road.
    Feb 2005
    Jul 2008
    I tend to agree with both viewpoints on Duo vs Quad. The best route to go would depend on how you utilize your computer. If you multitask a lot, quad is definitely the way to go. On the other hand, if you run one main process that you want to dedicate most of your CPU power to (eg. gaming), then Duo may be more bang for your buck.
    Most systems we build are Duo's, unless the system will be a real workhorse. If we're building a designer's PC, then we'll throw the Quad in.
    I would guess that most computer guru's would favour the Quad, simply for the benefits in responsiveness when multitasking. Personally I would find it very difficult to move back to a Duo after having used the Q6600 so long.
  1. FS : ACER 5630-6141 Notebook. Core2Duo T5500, 2GB RAM
    By NATE0513 in forum Computer Hardware & Peripherals
    Latest Threads: 08-30-2007, 03:05 PM
  2. FS: Intel Core2duo computer system
    By ugotahondaeh? in forum Computer Hardware & Peripherals
    Latest Threads: 05-14-2007, 04:23 PM
  3. WTB: Laptop- 64bit AMD or Core2Duo
    By Super_Geo in forum Computer Hardware & Peripherals
    Latest Threads: 04-25-2007, 09:23 AM
  4. Anyone with a core2duo processor I need some help.
    By rvd in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-13-2007, 05:14 AM
