Here is a routine a LARGE percentage of the lifters here could make great gains doing.
Monday
Squat or box squat 2-3 x 5
Glute/Ham Raises or pullthroughs 3 x 10
Bent Row or Chest Supported row 4 x 6
Barbell or Dumbbell Curl 3 x 8
Calf Raises 3 x 15
Wednesday
Bench Press or low board press 3 x 5, or 3 x 3
Incline Dumbbell Bench Press 4 x 8
Military or Dumbbell Shoulder Press 3 x 8
Skull Crushers 3 x 10
Ab work 3 x 10
Friday
Deadlift or rack deadlift 2-3 x 5
Leg press 2 x 10
Chin or lat pull-down 4 x 6
Calf Raises 3 x 15
Monday
Incline bench press or Incline Dumbbell Press 3 x 5, or 3 x 3
Tricep pushdowns 3 x 10
Ab work 3 x 10 Monday
FOR THOSE THAT ARE READING COMPREHENSION CHALLENGED THE SCHEDULE GOES LIKE THIS:
1st workout
Monday
Calf Raises 3 x 15
2nd workout 1 day later
Wednesday
Ab work 3 x 10
3rd workout 1 day later
Friday
Leg press 2 x 10
Calf Raises 3 x 15
4th workout After TWO DAYS OFF
Monday
next workout sequence repeat 1st through 4th workouts
Sets are NOT taken to failure, at least 1 rep short, or to the point RIGHT before form starts to break down. If you do not recover well, reduce 1 set from each of the lifts.
Rep cadence is explosive on the positive, controlled on the negative, no need to count cadence.
After warm-ups use the same weight for all sets. If you cannot get all the sets with the same weight, the weight is too heavy.
If you want to substitute something like dumbbell skull crushers for pushdowns, or hammer curls for barbell curls go ahead. DO NOT SUB OUT BIG COMPOUND MOVEMENTS FOR ISOLATION LIFTS. IF YOU CAN SQUAT AND DEADLIFT, DO THEM. THEY ARE THE MOST IMPORTANT LIFTS IN THE ROUTINE.
Rotate the lifts to something else every 4-8 weeks or whenever a lift stalls.
DELAOD BY DOING 1/2 THE SETS, OR 85% OF THE WEIGHT EVERY 4-8 WEEKS (4-5 WEEKS WORKS BEST FOR MOST PEOPLE.
Suitable substitute lifts:
Squat or box squat, you can front squat, or smith squat (smith ONLY if that is all you can do) You can leg press ONLY IF YOU ABSOLUTELY CANNOT DO REAGULAR SQUATS AND THE RESULTS WILL NOT BE AS GOOD.
Bent Row or Chest Supported row, you can dumbbell row or machine row
Barbell or Dumbbell Curl, you can do any curl variation
Calf Raises, you can do leg press calfs, standing barbell calf raises, or 1 arm, 1 leg dumbbell calf raises if you don't have a machine
Bench Press or low board press, you can do dumbbell presses or dips
Incline Dumbbell Bench Press, Dumbbell inclines, or smith inclines (use the SMITH ONLY IF THAT IS THE ONLY THING YOU CAN DO
Military or Dumbbell Shoulder Press, NO SUBS
Skull Crushers, you can do dumbbell skull crushers, overhead tricep extensions with a bar or dumbbells, or tricep push-downs if any of these movements bother your elbows.
Ab work, you can do a weighted sit-up, hanging leg raises, ab-wheel, or an ab machine
Deadlift or rack deadlift, you can do romanian deadlifts, or good-mornings
Leg press, you can front squat
Chin or lat pull-down, NO SUBS
Barbell or Dumbbell Curl, any curl variation
Incline bench press or Incline Dumbbell Press, NO SUBS
Dumbbell Bench Press, You can do dips
Military or Dumbbell Shoulder Press, you can do upright rows
Tricep pushdowns, you can do a skull crusher, or overhead tricep extension with a barbell or dumbbells
Ab work 3 x 10, You can do a weighted sit-up, hanging leg raises, ab-wheel, or an ab machine
If you can't sub any of these lifts figure it out yourself and quit asking endless questions about what you can sub. The sub list just posted was created after over 100 questions have been asked about "can I do lift B instead of lift A.
Iron Addict
