what it started like in spring 2007
then the first step took place
then the sr20det couldnt handle what I was throwing at it so I had to do a rebuild
Heres the parts pile for the engine.
Here is all the parts in the engine
and as she sits currently
just waiting on a new cold pipe and need to make a throttle cable bracket.
here is all the mods I have done:
5-speed swap ( yes it was auto when I got it)
255 LPH HO fuel pump
Koyo Radiator
ACT 6-puck disc
ACT Heavy Presure Plate
ACT Clutch Alignment Tool
ACT Pilot Bearing
ACT Release Bearing
Fly-Wheel Machining
Greddy Spec-M Intercooler kit
Meagan Downpipe 3"
HKS super Sequential BOV
HKS Steel Flange 65mm
Blitz 3" Exhaust
5-Speed Swap Parts
SR20DET
Meagan Test Pipe
Greddy Hot Pipe
Meagan Bottom Mount Manifold
Greddy Turbo Elbow
Meagan Motor Mounts
Flex a Lite duel fans (electric)
Battery Relocation Kit
Tomei 740cc Fuel Injectors
Z32 MAF
Optima Battery
Battery Kill switch
GT2871r .86 a/r
Tomei Rocker Arm Stoppers
Greddy Oil filter relocation
CP forged pistons 86.5mm
Eagle Rods
Coated Bearings
Tomei Head gasket
Tomei 260 Poncams Intake
Tomei 260 Poncams Exhaust
Tomei solid Piviot lifters
Tomei Valve springs
ACT Flywheel
Tomei Throttle body
Greddy Intake Manifold
Brian Crowler Intake and Exhaust valves
ACL Thrust washers Set
Greddy Catch Can
