Well I have owned this car since last Jun and it has been a bit of a pain. I first bought it and after 2 weeks of driving the water pump went out, replaced it and hit up the dyno at VEX in Red Deer for a baseline and it went again. We realized it was actually the clutch fan that seized and was the real culprit. This time it blew the head gasket aswell. I though ahh simple just throw a new one on but when we got the head off realized the block was a little warped and need to be machined so what the hell time to throw some nice parts in...
So the parts list for the engine and car:
- HKS 264/264 cams
- HKS cam gears
- HKS timing belt
- HKS fuel pressure regulator
- HKS fuel rail
- HKS boost controller
- HKS 1.6mm headgasket
- Denso Sard 800cc top feed high impedance injectors
- Dual Walbro 255 fuel pumps
- Haltech E11v2 ECU with plug & play harness (another J-spec perk)--------has been changed out for a Haltech Platinum Sport 2000
- Haltech 3-bar MAP sensor
- Tomei 86.5mm oversized forged pistons
- Tomei H-beam rods (with ARP L19 bolts)
- OEM standard sized main and rod bearings (properly sized and ordered)
- ARP head studs
- ARP main studs
- Garrett GT35r turbo with Tial stainless v-band exhaust housing (v-band to manifold and downpipe)
- Tial 44mm wastegate
- Blitz intercooler kit, with some Epic changes
- ATI dampened crank pulley
- Boost Logic billet timing belt tensioner bracket
- OS Giken STR2CD Twin Plate sprung disc clutch (looks so sweet)
- All new OEM timing covers and valve covers
- Epic Welding ceramic coated stainless exhaust manifold
- TRD front strut tower brace
- HKS Hipermax III coilovers
- Upgrade to the OEM larger brakes with all new calipers, rotors, etc.
- CCW SP500 18x10" and 18x11.5" wheels
- Toyo R888 265/35 and 315/30's
- "Toyota" emblem on hatch (J-Spec did not come with one)
- New 93-96 tail lights (97+ be damned, haha)
pistons
rods
block/head
assembly
