In flawless condition. No scratches/dents whatsoever on the body and the screen is perfect... absolutely no dead pixels.
Size/Type 19" wide-screen TFT LCD Native Resolution 1440 x 900 Contrast Ratio 2000:1 (ACM) Horizontal Viewing Angle 160 Vertical Viewing Angle 160 Pixel Pitch 0.284mm Brightness (typical) 300 cd/m2 Response Time (typical) 5ms Audio No speakers Signal Connectors VGA (15-pin D-Sub) HDCP Support N/A Chassis Color Black Power Voltage 100-240V AC adapter Internal Power consumption <37W Kensington® Lock Supported VESA Wall Mount Supported, 100mm Dimensions & Weight Dimensions 447.9 x 377.6 x 189.8 mm Weight 4.4kg
$140 obo
http://calgary.kijiji.ca/c-ViewAd?Ad...08527454%3B%3B
