I need to totally remove the paint and primer off of certain parts of my car...someone told me use brake fluid...anything else work well?
Red Deer, AB
There is an actual product you can find at any parts store called Automotive Paint Stripper. This works wonders.
Also look for Airline Paint Stripper. That shit will eat away at almost anything.
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
just goto an automotive paint store are buy gunwash, it'll take it off leasy. dont use brake fluid or anything like that though because it'll soak into the metal and when you goto paint that part again it wont stick and it will bubble.
Hi power presure washer... Don't know if it's safe... Might take more than your paint off...
aircraft paint remover or something like that...people use it to completely strip paint off of valve covers, its a really stronger paint stripper that should do what ur lookin for
I used a little something from rona called "paint and varnish remover". this stuff works wonders, and its not deadly like aircraft stripper. you still need to wear gloves with it, but its cheaper than the aircraft stripper
Solid Gino......
bead blast it
well my friend, you are taking another trip to ackalands for a few cans of airline paint striper. DO NOT let the product get on to any plastic parts. it will eat right through them.. make sure to mask of the pannel so this does not happen. Also, wear a mask. the fumes are really bad and will get to ya after awhile (speaking of experience if course). then put a big peice of carboard under the area and use a rubber scraper to pull everything down. wipe the surface with thinner and you got your self some bare metal
Originally posted by rage2
um.. at work we use airline paint stripper. half the jug will strip a hood in 10 min. just spread it on the hood, and cover it with masking paper, plasticy side down. then use a metal scraper, to clean it off. just keep the paper on the goop, or the melted paint will dry and stick to the hood. then sand smooth. takes about 20 min to do it. Jus be CAREFUL not to pour it on any bondo or bodywork. any spills just use water to clean, wear rubber gloves.( it burns )
ALSO, if your doing a hood, mask off the underside good,or any other panels with ordinary masking tape.
i don't know how to spell is correctly, but lacker tinner and rub like a mother fucker, and it will come off
I just had a thought, are you talking about overspray?
if it is plactic dont use thinner unless it is #11 but you have to rub like a mother fucker if you want stroner stuff use thinner #19 this shit will burn right through you hands but if it is plastic then it will take the plastic off too...........i work with this shit every day if you want me to help you out pm me
oh and it is also called thinner #140
Ok this is how we will strip your paint. You drive past while Vwbloke moons you. Jk chris
Rev high, ride low.
