AS title states I have a Gateway GT5634H tower /w 20" LG LCD Display for sale
comp specs:
Processor Intel® Core™ 2 Duo E4500 dual core processor
Each core operates at 2.2 GHz
2 MB shared L2 cache
800 MHz front side bus
Chipset Intel 945G Memory
Installed: 3072 MB DDR2, 667 MHz, (PC2-5300) dual channel memory (two 1024 MB and two 512 MB modules)
Expandable to: 4 GB (four DDR2 DIMM slots) Hard Drive 400 GB, 7200 RPM, SATA II hard drive
Support for up to two hard drives Optical Drive DVD ±RW, 18X multi-format dual layer drive (up to 8.5 GB)
Write max: 18X DVD+R, 18X DVD-R, 8X DVD+R DL, 8X DVD-R DL, 8X DVD+R DL, 8X DVD+RW, 6X DVD-RW, 12X DVD-RAM, 48X CD-R, 32X CD-RW
Read max: 16X DVD-ROM, 48X CD-ROM
Supports Labelflash™ on disc printing (req. Labelflash media)
Media Card Reader 15-in-1 high speed digital media manager supporting the following:
Compact Flash (CF) I, II
IBM Microdrive™ (MD)
SmartMedia Card (SMC)
Memory Stick™ (MS)
Memory Stick Duo (MS Duo)
Memory Stick PRO (MS PRO)
Memory Stick PRO Duo (MS PRO Duo)
Secure Digital™ (SD)
Mini Secure Digital (MiniSD)
Multi Media Card (MMC)
RS Multi Media Card (RS-MMC) (need adapter)
Multi Media Plus Card (MMC Plus)
Multi Media Mobile Card (MMC Mobile)
xD-Picture Card (xD)
Video NVIDIA® GeForce® 8500GT
256 MB onboard video memory
DirectX® 10, BluRay/HD-DVD Capable
Ports:
VGA
DVI-I with HDCP
S-Video
Audio Integrated 8-Channel (7.1) High Definition Audio Network Support Integrated Realtek 8111B 10/100 Mbps Ethernet LAN Power Supply 300 watt Add-in Card Slots
One PCI Express ×16 (graphics interface)
One PCI Express ×1
Two PCI conventional External Connectors
One PS/2 keyboard port
One PS/2 mouse port
One serial port
One parallel port
One VGA monitor port
Six USB ports (four rear, two front)
One RJ-45 Ethernet LAN port
Eight audio jacks (six rear, two front) Drive Bays Five total:
Two external 5.25-inch
One external 3.5-inch (with a docking bay for optional Gateway 2.5-inch removable USB hard drive)
Two internal 3.5-inch (hard drive)
Physical Dimensions
(H × W × D) 15.6 × 7.2 × 16.1 inches Weight (Unpackaged) Minimum 23.4 lbs. (varies with configuration)
Monitor specs
General
Display Type LCD display / TFT active matrix
Width 18.5 in
Depth 9.2 in
Height 15.8 in
Weight 10.1 lbs
Enclosure Color Black
Display (projector) image aspect ratio 16:10 Image brightness 300 cd/m2 Image Contrast Ratio 3000:1
Max horizontal view angle 170
Max vertical view angle 170
Display
Diagonal Size 20 in - Widescreen
Dot Pitch / Pixel Pitch 0.258 mm Max Resolution 1680 x 1050
Max Sync Rate (V x H) 75 Hz x 83 KHz
Response Time 3 ms Display Positions Adjustments Tilt
OSD Languages French , German , English , Italian
Video Output None
Signal Input DVI-D, VGA
Features F-ENGINE technology , sRGB color management
Video Input
Analog Video Signal RGB Digital Video Standard Digital Visual Interface (DVI) Audio Output
Type None
Expansion / Connectivity
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI
Miscellaneous
Flat Panel Mount Interface 100 x 200 mm
Features Wall mountable
Windows Vista Readiness Certified for Windows Vista
Compliant Standards CE , UL , cUL , FCC Class B certified
Power
Operational power consumption 34 Watt Operational power consumption (standby) 1 Watt
Environmental Standards
EPA Energy Star Compliant Yes
Comes with Hp Deskjet F4135 All-in-one Printer Scanner Copier New Never Used\
Computer come /w games installed
Steam (Counter Strike)
Unreal Tournament 3
World Of Warcraft WOTLK
Comes with System Restore discs (courtesy of future shop)
Can do a system restore if buyer prefers, Delivery is also available within Calgary city limits
435.00
