Vcore Voltage Low - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Vcore Voltage Low
    Default Vcore Voltage Low
    Hey guru's need your help.
    My PC reboots itself randomly and sometimes won't boot. BIOS is saying Vcore voltage to low (running approx 1.13-1.20v)
    I used to run this thing 10% overclocked, for about 3-4 yeras straight with no issues and this has just started to happen. Only way to get it to run and boot is to run with no overclock, but it is still unstable.
    Mobo is a Asus P4P800-E Deluxe w/ 2.6ghz P4.
    Any ideas as to wtf is happening and how to fix it?
    2020 Subaru Forester Sport
    check the caps
    Aug 2004
    belfast calgary/graciosa
    49cc Honda bicycle/89 Accord SE-i/59 Impala/93shaq
    try at lower memory speed 100mhz single channel
    All caps look fine. I will try lower memory speed.
    Nov 2003
    Try a different PSU.
    have you tried updating your mobos bios?
    http://support.asus.com/download/dow...800-E%20Deluxe
    Came back today to try and update BIOS. Back running at a steady 1.55x
    Will do the update anyways and see what happens.
    Nov 2003
    Calgary, Alberta, Canada, North America, Earth, The Milky Way . . .
    make sure the power supply connectors are tight in the socket, and the battery is fresh too
    also as a fyi, watch out for the usb on those boards failing out of the blue one day...
    its a known issue with these boards, and Ive got 2 of em
    Thanks rico!
    I don't use my home computer too much anymore, haven't been on it for ever to even update the bios or anything.
  1. low voltage at idle...
    By 03ozwhip in forum General Car/Bike Talk
    Latest Threads: 07-08-2008, 08:20 AM
  2. Replies: 1
    Latest Threads: 02-12-2008, 09:15 PM
  3. FS: Led white or blue DC voltage
    By SuperG3 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-05-2004, 12:40 AM
  4. Voltage Regulator??
    By CelicaST-162 in forum Mechanical
    Latest Threads: 04-17-2004, 09:19 AM
  5. Wiring a voltage regulator
    By Lightnen in forum Mechanical
    Latest Threads: 12-09-2003, 02:06 PM
