Vehicle Details
Year : 1990
Make and Model : Honda Civic DX
Exterior Color : White
Interior Color : Black
Auto or Manual? : Manual
Odometer Reading : Contact
Location of Vehicle : Edson, Alberta
Description :
Posting for a friend
As much as it KILLS me to do this, i'm going to have to start considering selling this as i'm going to be laid off soon, and i'd like to clear some debt while i still can
This is a SERIOUSLY built EF hatch that gets moving very quickly, in a very short amount of time.
1990 Honda Civic DX Hatchback
RH Evolution rims
BfGoodrich Gforce tires
1993 B18a1 engine
yonaka engine mounts
frog conversion harnass obd0-0bd1
Bottom End
Eagle forged rods
je srp forged pistons with rings
acura gasket set (bottom end)
acl bearings
dayco timing belt
str block guard
new oil pump
new water pump
STR block guard
Top End
acura head gasket
rebuild head
arp head bolts
crane springs/retainers
Transmission
jdm s80 transmission with LSD
install s80 internals in 92 ys1 case
Action chromoly pressure plate
action 2md clutch
Turbo parts
Precision GT3251E with .48 ar turbine housing
RC 750 cc injectors (saturated)
Honda S300 with PR4 ECU
kavlico 3.5 bar map sensor
inlinepro stainless steel turbo manifold
tig welded downpipe
turbosmart 35 mm wastegate
turbo xs rfl bov
turbosmart 2 stage electric boost controller
vibrant 2 inch silicone couplers
moroso catchcan
walboro 255 hp fuel pump
b&m fuel pressure regulator
b&m fuel pressure gauge
plx m300 wideband
johnnyracecar 6" intercooler
egt gauge
oil pressure gauge line and fittings
westach boost gauge
3" mandrel exhaust
Misc
traction bar/front crossmember
PIC coilovers(6 total) 2 rear 18k drag coil overs
hayden oil cooler thermo adapter with external oil cooler
ngk spark plugs
A pillar 3 gauge mount kit
autometer oil temp guage and weld in adapter
Stripped interior from the front seats back (Si rear seats included)
The car is appraised at $19,500 and comes with the appraisal.
The car does have some rust and the paint is a bit faded. It was the last step on the project but just never happened. This car is the ultimate sleeper. If you want it to look super pretty then get a paint job done on it, if you want to be one of the fastest civic’s out there then just get in and start driving
I did not build this car, it was purchased this way last fall, i'm just not going to be able to keep both this, and my acura.
Asking Price : $7000 FIRM
Contact Information
E-Mail : [email protected]
Phone : 780-725-1988 (jory)
Pictures :
