I'm attempting to install xp pro sp2(CD) onto one of two older IDE hard drives (seagate 80GB or samsung 120GB) the samsung used to be my primary HD until i swapped to a 320GB SATA; and has since been put into an external enclosure and run as an ext. HD.
A friend's old IDE HD seems to have crapped out, so i'm trying to load XP Pro SP2 onto it so i can install the new drive into their computer. I dont have the time to install on their computer so I'm trying to install on either my work computer or home desktop.
No matter what configuration i use i always get an BSOD stop error during install when the xp boot sequence is loading. something along the lines of 0x0000007B (i think) recommending CHKDSK function and says it crashed to save possible damage to my hard drive?
I've reformatted, used repair console chkdsk functions, enabled correct settings in BIOS, attempted installing to the drive as an external HD, as well as on the ribbon as master, and slave, with and without the other SATA drives present or just the IDE by itself...pretty much every configuration i can think of. I've completely run out of ideas as to what it might be...
at first i thought one of the drives might be crapping out, but I've attempted with both with identical results on both work and home computer, and the drives function fine in the ext. HD enclosure as mass storage...help??
