Laptop Battery Help - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Laptop Battery Help
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    Default Laptop Battery Help
    I have a HP dv5000 laptop, it`s a couple years old. About 2 months ago I was having problems with the original battery no longer holding a good charge. I purchased a new battery and it worked fine for a couple weeks.
    Now, neither of the batteries are holding a charge at all. When I plug in the charger, it only shows as the laptop running off ac power and the battery not charging at all.
    I`m trying to determine whether the problem is the batteries themselves or whether there is a problem with the connection between the battery and laptop.
    Any help appreciated.
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    One other note is that now when I start up the laptop it boots, loads everything and then usually cuts out and dies within a minute or two of starting.
    May 2009
    to answer second message, seems it's running on battery
    take out battery and run off the A/C - let me know if it starts
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    I've tried running without the battery and it won't power on.
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    One more bump... anybody have any ideas?
    May 2005
    Subaru Impreza
    I reckon the solder points on the AC jack inside the laptop are broken. Try moving the adapter end inside the laptop around firmly and carefully until you get a 'power' light. If not, and you feel adventurous, open the back cover so that jack is visible on the PCB and visually look for a break. If you see a break or can confirm it, break out the soldering iron.
    Aug 2004
    Back in Calgary
    03 Mdx, 05 Gli
    I'll open it up and check it out. Thanks.
  1. Battery Tender vs Battery Charger
    By ruggedboy in forum Bike Talk
    Latest Threads: 03-05-2009, 08:58 AM
  2. Laptop battery help
    By colinderksen in forum Computers, Consoles, and other Electronics
    Latest Threads: 12-02-2008, 11:10 PM
  3. Battery/Alternator Issues - Battery Light - Car Stalls
    By adamq in forum General Car/Bike Talk
    Latest Threads: 07-11-2007, 10:54 PM
  4. Rogers V3 battery vs. Telus V3c battery?
    By topher91 in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-05-2006, 08:53 PM
  5. WTB: Laptop HDD 2.5" 9.5cm/MMC-2 CPU/replacement Battery/PC3200 RAM
    By AllGoNoShow in forum Computer Hardware & Peripherals
    Latest Threads: 01-15-2005, 02:44 PM
